数据: LM20333 36V, 3A Synchronous Buck Regulator with Frequency Synchronization 数据表
LM20333是一款全功能同步降压稳压器,能够提供高达3A的负载电流。电流模式控制环路仅通过两个组件进行外部补偿,提供高性能和易用性。该器件经过优化,可在4.5V至36V的输入电压范围内工作,非常适合高压系统。
该器件具有内部过压保护(OVP)和过流保护(OCP)电路提高系统可靠性。精密的Enable引脚和集成的UVLO可以严格控制和排序器件的开启。启动浪涌电流受内部固定和外部可调软启动电路的限制。集成电源良好(PGOOD)电路可实现故障检测和电源排序。
LM20333设计用于多轨电源架构。器件的输出电压可配置为使用SS /TRK引脚跟踪更高的电压轨。如果LM20333的输出在启动时预偏置,它将不会吸收电流以将输出拉低,直到内部软启动斜坡超过反馈引脚的电压。
LM20333的开关频率可以使用SYNC引脚同步到外部时钟。 SYNC引脚能够同步到250 kHz至1.5 MHz的输入信号。
LM20333采用裸露焊盘20引脚HTSSOP封装,可焊接到PCB上,无需使用笨重的散热器。
所有商标均为其各自所有者的财产。
Vin (Min) (V) |
Vin (Max) (V) |
Vout (Min) (V) |
Vout (Max) (V) |
Iout (Max) (A) |
Regulated Outputs (#) |
Switching Frequency (Min) (kHz) |
Switching Frequency (Max) (kHz) |
Iq (Typ) (mA) |
Features |
Control Mode |
Duty Cycle (Max) (%) |
Operating Temperature Range (C) |
Rating |
Package Group |
LM20333 | LM20343 | LM21305 | LM3102 | LM3102-Q1 |
4.5 | 4.5 | 3 | 4.5 | 4.5 |
36 | 36 | 18 | 42 | 42 |
0.8 | 0.8 | 0.6 | 0.8 | 0.8 |
32 | 32 | 0.6 | 7 | 7 |
3 | 3 | 5 | 2.5 | 2.5 |
1 | 1 | 1 | 1 | 1 |
250 | 250 | 300 | 200 | 200 |
1500 | 1000 | 1500 | 1000 | 1000 |
2.3 | 2.3 | 9 | 1 | 1 |
Enable Frequency Synchronization Power Good Pre-Bias Start-Up Synchronous Rectification Tracking | Adjustable Current Limit Enable Power Good Pre-Bias Start-Up Synchronous Rectification Tracking | Enable Frequency Synchronization Power Good Pre-Bias Start-Up Synchronous Rectification | Enable Synchronous Rectification Tracking | Enable Synchronous Rectification |
Current Mode | Current Mode | Current Mode | COT with emulated ripple | COT with emulated ripple |
80 | 80 | 100 | 94 | 94 |
-40 to 125 | -40 to 125 | -40 to 85 | -40 to 125 | -40 to 125 |
Catalog | Catalog | Catalog | Catalog | Automotive |
HTSSOP | HTSSOP | WQFN | DSBGA HTSSOP | HTSSOP |
