数据: TPS5438x Dual 3-A Non-Synchronous Converters With Integrated High-Side MOSFET 数据表
TPS54383和TPS54386是双输出,非同步降压转换器,能够支持在4.5 V至28 V范围内工作的3A输出应用输入电源电压,要求输出电压在输入电压的0.8 V和90%之间。
通过内部确定的工作频率,软启动时间和控制环路补偿,这些转换器提供了许多功能最少的外部组件。通道1过流保护设置为4.5 A,而通道2过流保护水平通过将引脚连接到地,BP或左浮动来选择。设置级别用于允许为不需要两个输出的满载功能的应用程序扩展外部组件。
输出可以单独启用,也可以配置为允许比率度量或顺序启动排序。此外,两个输出可以从不同的来源供电。
Vin (Min) (V) |
Vin (Max) (V) |
Vout (Min) (V) |
Vout (Max) (V) |
Iout (Max) (A) |
Regulated Outputs (#) |
Switching Frequency (Min) (kHz) |
Switching Frequency (Max) (kHz) |
Iq (Typ) (mA) |
Features |
Control Mode |
Duty Cycle (Max) (%) |
Operating Temperature Range (C) |
Rating |
Package Group |
TPS54386 | TPS54383 | TPS55383 | TPS55386 |
4.5 | 4.5 | 4.5 | 4.5 |
28 | 28 | 28 | 28 |
0.8 | 0.8 | 0.8 | 0.8 |
25.2 | 25.2 | 25.2 | 25.2 |
3 | 3 | 3 | 3 |
2 | 2 | 2 | 2 |
600 | 300 | 300 | 600 |
1.8 | 1.8 | 1.8 | 1.8 |
Enable Phase Interleaving | Enable Phase Interleaving | Enable Phase Interleaving | Enable Phase Interleaving |
Current Mode | Current Mode | Current Mode | Current Mode |
85 | 90 | 90 | 85 |
-40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 |
Catalog | Catalog | Catalog | Catalog |
HTSSOP | HTSSOP | HTSSOP | HTSSOP |
