LM27402是一款具有无损电感器DCR电流检测功能的电压模式同步直流/直流降压控制器。感测电感电流无需增加阻性功率传输系统元件,这可以提升整体效率,并且有助于连续执行精确的电流感测.0.6V±1%的电压基准确保了输出端的高精度和低压特性.LM27402的输入工作电压范围为3V至温度为20V,适用于多种输入电源轨。
LM27402电压模式控制环路整合了输入电压前馈,从而在整个输入电压范围内保持稳定性。开关频率可在200kHz至
1.2MHz之间调节。双路高电流集成式MOSFET驱动器支持大Q G ,低R DS(on)的功耗MOSFET。电源正常指示器可提供电源轨定序功能和输出故障检测。可调外部软启动可限制浪涌电流,并在启动期间提供单调输出控制。其他特性包括外部跟踪其他电源,集成式LDO偏置电源以及同步功能。
所有商标均为各自所有者的财产。
Vin (Min) (V) |
Vin (Max) (V) |
Vout (Min) (V) |
Vout (Max) (V) |
Iout (Max) (A) |
Regulated Outputs (#) |
Number of Phases |
Switching Frequency (Min) (kHz) |
Switching Frequency (Max) (kHz) |
Iq (Typ) (mA) |
Features |
Duty Cycle (Max) (%) |
Operating Temperature Range (C) |
Rating |
Package Group |
Control Mode |
LM27402 | LM27403 | LM2748 |
3 | 3 | 1 |
20 | 20 | 14 |
0.6 | 0.6 | 0.6 |
18.6 | 19 | 12 |
30 | 30 | 20 |
1 | 1 | 1 |
1 | 1 | 1 |
200 | 200 | 50 |
1200 | 1200 | 1000 |
4.5 | 3.5 | 1.7 |
Enable Frequency Synchronization Power Good Pre-Bias Start-Up Synchronous Rectification Tracking | Enable Frequency Synchronization Power Good Pre-Bias Start-Up Remote Sense Synchronous Rectification Tracking | Enable Power Good Synchronous Rectification Tracking |
95 | 93 | 86 |
-40 to 125 | -40 to 125 | -40 to 125 |
Catalog | Catalog | Catalog |
HTSSOP WQFN | WQFN | TSSOP |
Voltage Mode | Voltage Mode | Voltage Mode |
