数据: TPS54240 3.5-V to 42-V Step-Down DC - DC Converter With Eco-Mode™ 数据表
The TPS54240 device is a 42-V, 2.5-A, step-down regulator with an integrated high-side MOSFET. Current mode control provides simple external compensation and flexible component selection. A low-ripple, pulse skip mode reduces the no load, regulated output supply current to 138 µA. Using the enable pin, shutdown supply current is reduced to 1.3 µA, when the enable pin is low.
Undervoltage lockout is internally set at 2.5 V, but it can be increased using the enable pin. The output voltage startup ramp is controlled by the slow-start pin that can also be configured for sequencing and tracking. An open-drain power good signal indicates the output is within 94% to 107% of its nominal voltage.
A wide switching frequency range allows efficiency and optimization of external component size. Frequency foldback and thermal shutdown protects the part during an overload condition.
The TPS54240 is available in 10-pin, thermally-enhanced HVSSOP and 10-pin 3-mm × 3-mm PowerPAD package.
Vin (Min) (V) |
Vin (Max) (V) |
Vout (Min) (V) |
Vout (Max) (V) |
Iout (Max) (A) |
Regulated Outputs (#) |
Switching Frequency (Min) (kHz) |
Switching Frequency (Max) (kHz) |
Iq (Typ) (mA) |
Features |
Control Mode |
Duty Cycle (Max) (%) |
Operating Temperature Range (C) |
Rating |
Package Group |
TPS54240 | TPS54040A | TPS54140A | TPS54240-Q1 | TPS54340 | TPS54341 | TPS54540 | TPS54541 |
3.5 | 3.5 | 3.5 | 3.5 | 4.5 | 4.5 | 4.5 | 4.5 |
42 | 42 | 42 | 42 | 42 | 42 | 42 | 42 |
0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 |
39 | 39 | 39 | 39 | 41 | 41 | 41.1 | 41 |
2.5 | 0.5 | 1.5 | 2.5 | 3.5 | 3.5 | 5 | 5 |
1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 |
2500 | 2500 | 2500 | 2500 | 2500 | 2500 | 2500 | 2500 |
0.138 | 0.116 | 0.116 | 0.138 | 0.146 | 0.152 | 0.146 | 0.152 |
Enable Frequency Synchronization Light Load Efficiency Power Good Tracking UVLO Adjustable | Enable Frequency Synchronization Light Load Efficiency Power Good Tracking UVLO Adjustable | Enable Frequency Synchronization Light Load Efficiency Power Good Tracking UVLO Adjustable | Enable Frequency Synchronization Light Load Efficiency Power Good Tracking UVLO Adjustable | Enable Frequency Synchronization Light Load Efficiency UVLO Adjustable | Enable Frequency Synchronization Light Load Efficiency Power Good Tracking UVLO Adjustable | Enable Frequency Synchronization Light Load Efficiency UVLO Adjustable | Enable Frequency Synchronization Light Load Efficiency Power Good Tracking UVLO Adjustable |
Current Mode | Current Mode | Current Mode | Current Mode | Current Mode | Current Mode | Current Mode | Current Mode |
98 | 98 | 98 | 100 | 98 | 98 | 98 | 98 |
-40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 85 | -40 to 125 | -40 to 85 |
Catalog | Catalog | Catalog | Automotive | Catalog | Catalog | Catalog | Catalog |
MSOP-PowerPAD VSON | MSOP-PowerPAD VSON | MSOP-PowerPAD VSON | MSOP-PowerPAD VSON | SO PowerPAD | WSON | SO PowerPAD | WSON |
型号:TPS54240DGQR 封装:HVSSOP10_3X3MM_EP
品牌:TI 描述:降压型-40℃~+150℃@(TJ)1降压可调0.8V~39V 2.5A 3.5V~42V 2.5MHz HVSSOP10_3X3MM_EP DC-DC转换器ROHS
金额:¥2.16300
去购买型号:TPS54240QDGQRQ1 封装:HVSSOP10_3X3MM_EP
品牌:TI 描述:NO降压型-40℃~+125℃@(TA)1降压可调0.8V~39V 2.5A 3.5V~42V HVSSOP10_3X3MM_EP DC-DC转换器ROHS
金额:¥51.20500
去购买
