LM25119器件是一款双路同步降压控制器,适用于高压电源或变化范围较大的输入电源的降压稳压器应用。此控制方法基于采用仿真电流斜坡的电流模式控制。电流模式控制可提供内部线路前馈,逐周期电流限制和简化的环路补偿。通过使用仿真电流斜坡可降低脉宽调制电路的噪声灵敏度,从而对高输入电压应用中所需的极小占空比进行可靠控制。开关频率可设定在50kHz至750kHz范围内.LM25119器件可驱动支持自适应死区时间控制的外部高侧和低侧N通道MOS功率开关。用户可选二极管仿真模式可实现断续模式运行,从而提高轻负载条件下的效率。凭借高压偏置稳压器以及自动切换至外部偏置的功能,可以进一步提高效率。特性包括:热关断,频率同步,逐周期和断续模式电流限制以及可调节线路欠压锁定。该器件采用耗增强型32引脚无引线WQFN封装,并且配有利于散热的外露芯片连接焊盘。
所有商标均为其各自所有者的财产。
Vin (Min) (V) |
Vin (Max) (V) |
Vout (Min) (V) |
Vout (Max) (V) |
Iout (Max) (A) |
Regulated Outputs (#) |
Number of Phases |
Switching Frequency (Min) (kHz) |
Switching Frequency (Max) (kHz) |
Iq (Typ) (mA) |
Features |
Duty Cycle (Max) (%) |
Operating Temperature Range (C) |
Rating |
Package Group |
Control Mode |
LM25119 | LM25117 | LM25117-Q1 | LM5117 | LM5117-Q1 | LM5119 |
4.5 | 4.5 | 4.5 | 5.5 | 5.5 | 5.5 |
42 | 42 | 42 | 65 | 65 | 65 |
0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 |
41.3 | 41 | 41 | 62 | 62 | 64 |
40 | 20 | 20 | 20 | 20 | 15 |
2 | 1 | 1 | 1 | 1 | 2 |
50 | 50 | 50 | 50 | 50 | 50 |
750 | 750 | 750 | 750 | 750 | 750 |
6 | 4.8 | 4.8 | 4.8 | 4.8 | 6 |
Adjustable Current Limit Enable Frequency Synchronization Light Load Efficiency Synchronous Rectification UVLO Adjustable | Adjustable Current Limit Enable Frequency Synchronization Light Load Efficiency Synchronous Rectification Tracking UVLO Adjustable | Adjustable Current Limit Enable Frequency Synchronization Light Load Efficiency Synchronous Rectification Tracking UVLO Adjustable | Adjustable Current Limit Enable Frequency Synchronization Light Load Efficiency Synchronous Rectification Tracking UVLO Adjustable | Adjustable Current Limit Enable Frequency Synchronization Light Load Efficiency Synchronous Rectification Tracking UVLO Adjustable | Adjustable Current Limit Enable Frequency Synchronization Light Load Efficiency Synchronous Rectification UVLO Adjustable |
98 | 98 | 98 | 98 | 98 | 98 |
-40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 |
Catalog | Catalog | Automotive | Catalog | Automotive | Catalog |
WQFN | HTSSOP WQFN | HTSSOP WQFN | HTSSOP WQFN | HTSSOP WQFN | WQFN |
Current Mode | Current Mode | Current Mode | Current Mode | Current Mode | Current Mode |
