数据: TPS54328 4.5-V to 18-V Input, 3-A Synchronous Step-Down Converter With Eco-Mode™ 数据表
TPS54328是一款自适应导通时间D-CAP2™模式同步降压转换器。 TPS54328使系统设计人员能够以经济高效,低元件数,低待机电流的解决方案完成各种终端设备电源总线稳压器套件。 TPS54328的主控制环路采用D-CAP2模式控制,无需外部补偿元件即可提供快速瞬态响应。
自适应导通时间控制支持在较高负载条件下PWM模式之间的无缝转换。轻载时的生态模式操作。 Eco模式允许TPS54328在较轻负载条件下保持高效率。 TPS54328还具有专有电路,使器件能够采用低等效串联电阻(ESR)输出电容(如POSCAP或SP-CAP)和超低ESR陶瓷电容。该器件采用4.5 V至18 V输入(V IN )工作。
输出电压可在0.76 V至7 V范围内编程。该器件还具有可调节功能软启动时间。 TPS54328采用8引脚DDA和10引脚DRC封装,工作环境温度范围为-40°C至85°C。
Vin (Min) (V) |
Vin (Max) (V) |
Vout (Min) (V) |
Vout (Max) (V) |
Iout (Max) (A) |
Regulated Outputs (#) |
Switching Frequency (Min) (kHz) |
Switching Frequency (Max) (kHz) |
Iq (Typ) (mA) |
Features |
Control Mode |
Duty Cycle (Max) (%) |
Operating Temperature Range (C) |
Rating |
Package Group |
TPS54328 | TPS54227 | TPS54228 | TPS54327 | TPS54427 | TPS54428 | TPS54627 | TPS54628 | TPS56428 | TPS56528 |
4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 |
18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 |
0.76 | 0.76 | 0.76 | 0.76 | 0.76 | 0.76 | 0.76 | 0.76 | 0.6 | 0.76 |
7 | 7 | 7 | 7 | 7 | 7 | 5.5 | 5.5 | 5.5 | 5.5 |
3 | 2 | 2 | 3 | 4 | 4 | 6 | 6 | 4 | 5 |
1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
700 | 700 | 700 | 700 | 650 | 650 | 650 | 650 | 650 | 650 |
0.8 | 0.8 | 0.8 | 0.8 | 0.95 | 0.95 | 0.95 | 0.95 | 0.25 | 0.25 |
Enable Light Load Efficiency Synchronous Rectification | Enable Synchronous Rectification | Enable Light Load Efficiency Synchronous Rectification | Enable Synchronous Rectification | Enable Synchronous Rectification | Enable Light Load Efficiency Synchronous Rectification | Enable Synchronous Rectification | Enable Light Load Efficiency Synchronous Rectification | Enable Light Load Efficiency Power Good Synchronous Rectification | Enable Light Load Efficiency Synchronous Rectification |
D-CAP2 | D-CAP2 | D-CAP2 | D-CAP2 | Current Mode | D-CAP2 | D-CAP2 | D-CAP2 | D-CAP2 | D-CAP2 |
90 | 90 | 90 | 90 | 95 | 95 | 85 | 85 | 85 | 85 |
-40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 125 | -40 to 125 | -40 to 85 | -40 to 125 |
Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
SO PowerPAD VSON | SO PowerPAD VSON | SO PowerPAD SOIC VSON | SO PowerPAD VSON | SO PowerPAD VSON | SO PowerPAD VSON | SO PowerPAD | SO PowerPAD | SO PowerPAD VQFN | SO PowerPAD |
