数据: LM5119 Wide Input Range Dual Synchronous Buck Controller (cn) 数据表 (Rev. E)
LM5119是双同步降压控制器,适用于高压降压稳压器应用或输入供应差异很大。该控制方法基于利用仿真电流斜坡的电流模式控制。电流模式控制提供固有的线路前馈,逐周期电流限制和易于环路补偿。仿真控制斜坡的使用降低了脉冲宽度调制电路的噪声灵敏度,允许可靠地控制高输入电压应用中所需的非常小的占空比。开关频率可在50kHz至750kHz范围内编程。 LM5119通过自适应死区时间控制驱动外部高端和低端NMOS电源开关。用户可选择的二极管仿真模式可实现非连续模式操作,从而在轻负载条件下提高效率。高压偏置调节器具有自动切换到外部偏置的功能,进一步提高了效率。其他功能包括热关断,频率同步,逐周期和打嗝模式电流限制以及可调节线路欠压锁定。该器件采用功率增强型无引线LLP-32封装,具有裸露的芯片粘接垫,有助于散热。
Vin (Min) (V) |
Vin (Max) (V) |
Vout (Min) (V) |
Vout (Max) (V) |
Iout (Max) (A) |
Regulated Outputs (#) |
Number of Phases |
Switching Frequency (Min) (kHz) |
Switching Frequency (Max) (kHz) |
Iq (Typ) (mA) |
Features |
Duty Cycle (Max) (%) |
Operating Temperature Range (C) |
Rating |
Package Group |
Control Mode |
LM5119 | LM25117 | LM25117-Q1 | LM25119 | LM5117 | LM5117-Q1 |
5.5 | 4.5 | 4.5 | 4.5 | 5.5 | 5.5 |
65 | 42 | 42 | 42 | 65 | 65 |
0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 |
64 | 41 | 41 | 41.3 | 62 | 62 |
15 | 20 | 20 | 40 | 20 | 20 |
2 | 1 | 1 | 2 | 1 | 1 |
50 | 50 | 50 | 50 | 50 | 50 |
750 | 750 | 750 | 750 | 750 | 750 |
6 | 4.8 | 4.8 | 6 | 4.8 | 4.8 |
Adjustable Current Limit Enable Frequency Synchronization Light Load Efficiency Synchronous Rectification UVLO Adjustable | Adjustable Current Limit Enable Frequency Synchronization Light Load Efficiency Synchronous Rectification Tracking UVLO Adjustable | Adjustable Current Limit Enable Frequency Synchronization Light Load Efficiency Synchronous Rectification Tracking UVLO Adjustable | Adjustable Current Limit Enable Frequency Synchronization Light Load Efficiency Synchronous Rectification UVLO Adjustable | Adjustable Current Limit Enable Frequency Synchronization Light Load Efficiency Synchronous Rectification Tracking UVLO Adjustable | Adjustable Current Limit Enable Frequency Synchronization Light Load Efficiency Synchronous Rectification Tracking UVLO Adjustable |
98 | 98 | 98 | 98 | 98 | 98 |
-40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 |
Catalog | Catalog | Automotive | Catalog | Catalog | Automotive |
WQFN | HTSSOP WQFN | HTSSOP WQFN | WQFN | HTSSOP WQFN | HTSSOP WQFN |
Current Mode | Current Mode | Current Mode | Current Mode | Current Mode | Current Mode |
