TPS56221器件是一款高效的大电流同步降压转换器,可由4.5V至14V范围内的电源供电运行。当负载电流高达25A时,该器件可产生低至0.6V的输出电压。集成的NexFET功率MOSFET尺寸小且易于使用。
该器件可通过电压前馈补偿实施电压模式控制,能够在输入电压变化时间即做响应。
TPS56221采用22引脚散热增强型PQFN(DQP)PowerPAD封装。
该器件支持高度的设计灵活性,可提供各种用户可编程功能,其中包括软启动,过流保护(OCP)电平以及环路补偿.ODP电平可通过ILIM引脚与电路接地之间连接的单个外部电阻进行编程。在初始上电排序过程中,该器件会进入校准周期,测量ILIM引脚电压,并设置内部OCP电压。在工作期间,器件可在通电时通过将可编程OCP电压与低侧FET两端的压降进行比较来判断是否为过状况。之后,器件会进入关断/重启周期,直到故障消除为止。
所有商标均为其各自所有者的财产。
Vin (Min) (V) |
Vin (Max) (V) |
Vout (Min) (V) |
Vout (Max) (V) |
Iout (Max) (A) |
Regulated Outputs (#) |
Switching Frequency (Min) (kHz) |
Switching Frequency (Max) (kHz) |
Iq (Typ) (mA) |
Features |
Control Mode |
Duty Cycle (Max) (%) |
Operating Temperature Range (C) |
Rating |
Package Group |
TPS56221 | TPS53353 | TPS53355 | TPS543B20 | TPS543C20 | TPS544C25 | TPS548B22 | TPS548D22 | TPS56121 |
4.5 | 1.5 | 1.5 | 4 | 4 | 4.5 | 1.5 | 1.5 | 4.5 |
14 | 15 | 15 | 19 | 16 | 18 | 18 | 16 | 14 |
0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.5 | 0.6 | 0.6 | 0.6 |
12 | 5.5 | 5.5 | 5.5 | 5.5 | 5 | 5.5 | 5.5 | 12 |
25 | 20 | 30 | 25 | 40 | 30 | 25 | 40 | 15 |
1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
300 | 250 | 250 | 300 | 300 | 200 | 425 | 425 | 300 |
1000 | 1000 | 1000 | 2000 | 2000 | 1000 | 1050 | 1050 | 1000 |
2.5 | 0.32 | 0.32 | 3 | 4.3 | 7.7 | 2 | 2 | 2.5 |
Enable Light Load Efficiency Pre-Bias Start-Up Synchronous Rectification | Adjustable Current Limit Enable Light Load Efficiency Power Good Pre-Bias Start-Up Synchronous Rectification | Adjustable Current Limit Enable Light Load Efficiency Power Good Pre-Bias Start-Up Synchronous Rectification | Enable Frequency Synchronization Over Current Protection Phase Interleaving Power Good Pre-Bias Start-Up Remote Sense Synchronous Rectification UVLO Adjustable | Adjustable Current Limit Enable Frequency Synchronization N/A Over Current Protection Phase Interleaving Power Good Pre-Bias Start-Up Remote Sense Synchronous Rectification | Adjustable Current Limit Dynamic Voltage Scaling Enable Frequency Synchronization PMBus Power Good Pre-Bias Start-Up Remote Sense Synchronous Rectification Tracking UVLO Adjustable Voltage Margining | Adjustable Current Limit Enable Light Load Efficiency Output Discharge Power Good Pre-Bias Start-Up Remote Sense Synchronous Rectification UVLO Adjustable | Adjustable Current Limit Enable Light Load Efficiency Output Discharge Power Good Pre-Bias Start-Up Remote Sense Synchronous Rectification UVLO Adjustable | Adjustable Current Limit Enable Power Good Pre-Bias Start-Up Synchronous Rectification |
Voltage Mode | D-CAP | D-CAP | Current Mode | Current Mode | Voltage Mode | D-CAP3 | D-CAP3 | Voltage Mode |
93 | 90 | 90 | 70 | 70 | 80 | 80 | 80 | 93 |
-40 to 125 | -40 to 85 | -40 to 85 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 |
Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
LSON-CLIP | LSON-CLIP | LSON-CLIP | LQFN-CLIP | LQFN-CLIP | LQFN-CLIP | LQFN-CLIP | LQFN-CLIP | LSON-CLIP |
