数据: TPS6208x 具有 DCS-Control 和贪睡模式的 1.2A、高效降压转换器 数据表 (Rev. F)
TPS6208x器件是高频同步降压转换器系列产品。该器件的输入电压范围为2.3V至6V,支持常用电池技术。此外,该器件可用于低电压系统电源轨。
TPS6208x专注于在宽输出电流范围下实现高效降压转换。该转换器在中等程度的负载到高负载时运行于脉宽调制( PWM)模式,并在轻负载电流条件下自动进入省电模式运行,从而在整个负载电流范围内保持高效率。为了在超低负载或无负载电流下保持高效率运行,该器件采用具有超低静态电流的贪睡模式。该功能通过MODE引脚使能,可延长增加电池驱动应用的运行时间,同时保持最低待机电流,以满足针对低待机电流的绿色能源标准。
为了满足系统电源轨需求,内部补偿电路支持使用高于100μF的外部输出电容。凭借DCS-Control架构,可实现出色的负载瞬态性能和输出电压调节精度。该器件采用带有散热焊盘的2mm x 2mm WSON封装。
所有商标均为其各自所有者的财产。
Vin (Min) (V) |
Vin (Max) (V) |
Vout (Min) (V) |
Vout (Max) (V) |
Iout (Max) (A) |
Regulated Outputs (#) |
Switching Frequency (Min) (kHz) |
Switching Frequency (Max) (kHz) |
Iq (Typ) (mA) |
Features |
Control Mode |
Duty Cycle (Max) (%) |
Operating Temperature Range (C) |
Rating |
Package Group |
TPS62080 | TLV62084A | TLV62085 | TLV62095 | TPS62097 | TPS62480 | TPS62821 | TPS62823 |
2.3 | 2.7 | 2.5 | 2.5 | 2.5 | 2.4 | 2.4 | 2.4 |
6 | 6 | 6 | 5.5 | 6 | 5.5 | 5.5 | 5.5 |
0.5 | 0.5 | 0.8 | 0.8 | 0.8 | 0.6 | 0.6 | 0.6 |
4 | 4 | 6 | 5.5 | 6 | 5.5 | 4 | 4 |
1.2 | 2 | 3 | 4 | 2 | 6 | 1 | 3 |
1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
2000 | 2000 | 2400 | 1400 | 1500 | 2000 | 2200 | 2200 |
2000 | 2000 | 2400 | 1400 | 2500 | 2500 | 2200 | 2200 |
0.0065 | 0.03 | 0.017 | 0.02 | 0.04 | 0.023 | 0.004 | 0.004 |
Enable Light Load Efficiency Load Disconnect Output Discharge Power Good Pre-Bias Start-Up Synchronous Rectification | Enable Light Load Efficiency Output Discharge Power Good Pre-Bias Start-Up Synchronous Rectification UVLO Fixed | Enable Light Load Efficiency Load Disconnect Output Discharge Over Current Protection Power Good Pre-Bias Start-Up Synchronous Rectification UVLO Fixed | Enable Light Load Efficiency Output Discharge Power Good Pre-Bias Start-Up Synchronous Rectification Tracking | Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Output Discharge Power Good Pre-Bias Start-Up Synchronous Rectification Tracking | Dynamic Voltage Scaling Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Output Discharge Over Current Protection Phase Interleaving Power Good Pre-Bias Start-Up Synchronous Rectification Tracking UVLO Fixed Voltage Margining | Enable Light Load Efficiency Output Discharge Over Current Protection Power Good Pre-Bias Start-Up Synchronous Rectification | Enable Light Load Efficiency Output Discharge Over Current Protection Power Good Pre-Bias Start-Up Synchronous Rectification |
Constant on-time (COT) DCS-Control | Constant on-time (COT) DCS-Control | Constant on-time (COT) DCS-Control | Constant on-time (COT) DCS-Control | Constant on-time (COT) DCS-Control | Current Mode | Constant on-time (COT) DCS-Control | Constant on-time (COT) DCS-Control |
100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 |
-40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 |
Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
WSON | WSON | VSON-HR | VQFN | VQFN-HR | VQFN-HR | VSON-HR | VSON-HR |
