TPS53353是一款具有集成MOSFET的D-CAP™模式,20A同步降压转换器。它们被设计用于易于使用,低外部组件数量和空间有限的电源系统。
这个器件特有5.5mΩ/2.2mΩ集成MOSFET,精准1%0.6V基准和集成的升压开关。具有竞争力的特性包括:1.5V至15V的转换输入电压范围,极低外部元件数,针对超快速瞬态响应的D-CAP™模式控制,自动跳跃模式操作,内部软启动控制,可选择频率以及无需补偿。
转换输入电压范围为1.5V至15V,电源电压范围为4.5V至5.5V。
该器件采用5mm×6mm,22引脚QFN封装,额定工作温度范围为-40°C至85°C。
所有商标均为其各自所有者的财产。
Vin (Min) (V) |
Vin (Max) (V) |
Vout (Min) (V) |
Vout (Max) (V) |
Iout (Max) (A) |
Regulated Outputs (#) |
Switching Frequency (Min) (kHz) |
Switching Frequency (Max) (kHz) |
Iq (Typ) (mA) |
Features |
Control Mode |
Duty Cycle (Max) (%) |
Operating Temperature Range (C) |
Rating |
Package Group |
TPS53353 | TPS51362 | TPS53318 | TPS53319 | TPS53355 | TPS543B20 | TPS543C20 | TPS544C25 | TPS548B22 | TPS548D22 | TPS56121 | TPS56221 | TPS56520 | TPS566250 | TPS56628 | TPS56720 |
1.5 | 3 | 1.5 | 1.5 | 1.5 | 4 | 4 | 4.5 | 1.5 | 1.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 |
15 | 22 | 22 | 22 | 15 | 19 | 16 | 18 | 18 | 16 | 14 | 14 | 17 | 17 | 18 | 17 |
0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.5 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.76 | 0.6 |
5.5 | 2 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5 | 5.5 | 5.5 | 12 | 12 | 1.87 | 1.87 | 5.5 | 1.87 |
20 | 10 | 8 | 14 | 30 | 25 | 40 | 30 | 25 | 40 | 15 | 25 | 5 | 6 | 6 | 7 |
1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
250 | 800 | 250 | 250 | 250 | 300 | 300 | 200 | 425 | 425 | 300 | 300 | 500 | 500 | 650 | 500 |
1000 | 800 | 1000 | 1000 | 1000 | 2000 | 2000 | 1000 | 1050 | 1050 | 1000 | 1000 | 500 | 500 | 650 | 500 |
0.32 | 0.1 | 0.32 | 0.32 | 0.32 | 3 | 4.3 | 7.7 | 2 | 2 | 2.5 | 2.5 | 0.92 | 0.9 | 0.95 | 0.92 |
Adjustable Current Limit Enable Light Load Efficiency Power Good Pre-Bias Start-Up Synchronous Rectification | Enable Light Load Efficiency Output Discharge Power Good Synchronous Rectification | Adjustable Current Limit Enable Light Load Efficiency Power Good Pre-Bias Start-Up Synchronous Rectification | Adjustable Current Limit Enable Light Load Efficiency Power Good Pre-Bias Start-Up Synchronous Rectification | Adjustable Current Limit Enable Light Load Efficiency Power Good Pre-Bias Start-Up Synchronous Rectification | Enable Frequency Synchronization Over Current Protection Phase Interleaving Power Good Pre-Bias Start-Up Remote Sense Synchronous Rectification UVLO Adjustable | Adjustable Current Limit Enable Frequency Synchronization N/A Over Current Protection Phase Interleaving Power Good Pre-Bias Start-Up Remote Sense Synchronous Rectification | Adjustable Current Limit Dynamic Voltage Scaling Enable Frequency Synchronization PMBus Power Good Pre-Bias Start-Up Remote Sense Synchronous Rectification Tracking UVLO Adjustable Voltage Margining | Adjustable Current Limit Enable Light Load Efficiency Output Discharge Power Good Pre-Bias Start-Up Remote Sense Synchronous Rectification UVLO Adjustable | Adjustable Current Limit Enable Light Load Efficiency Output Discharge Power Good Pre-Bias Start-Up Remote Sense Synchronous Rectification UVLO Adjustable | Adjustable Current Limit Enable Power Good Pre-Bias Start-Up Synchronous Rectification | Enable Light Load Efficiency Pre-Bias Start-Up Synchronous Rectification | Adjustable Current Limit Dynamic Voltage Scaling Enable Light Load Efficiency Power Good Pre-Bias Start-Up Synchronous Rectification Voltage Margining | Dynamic Voltage Scaling Enable Light Load Efficiency Power Good Synchronous Rectification UVLO Adjustable | Enable Light Load Efficiency Power Good Synchronous Rectification | Adjustable Current Limit Dynamic Voltage Scaling Enable Light Load Efficiency Power Good Pre-Bias Start-Up Synchronous Rectification Voltage Margining |
D-CAP | D-CAP2 | D-CAP | D-CAP | D-CAP | Current Mode | Current Mode | Voltage Mode | D-CAP3 | D-CAP3 | Voltage Mode | Voltage Mode | D-CAP2 | D-CAP2 | D-CAP2 | D-CAP2 |
90 | 87 | 90 | 90 | 90 | 70 | 70 | 80 | 80 | 80 | 93 | 93 | 80 | 80 | 85 | 80 |
-40 to 85 | -10 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 |
Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
LSON-CLIP | VQFN-CLIP | LSON-CLIP | LSON-CLIP | LSON-CLIP | LQFN-CLIP | LQFN-CLIP | LQFN-CLIP | LQFN-CLIP | LQFN-CLIP | LSON-CLIP | LSON-CLIP | HTSSOP | SO PowerPAD | SO PowerPAD | HTSSOP |
型号:TPS53353DQPR 封装:LSON22_6X5MM_EP
品牌:TI 描述:功能类型:降压型 输出类型:可调 输入电压:1.5~15V 输出电压:0.6~5.5V 输出电流(最大值):20A
金额:¥5.72401
去购买
