TPS40322器件是双输出同步降压控制器。它也可以配置为单输出,两相控制器。 180°异相操作可降低输入电流纹波并延长输入电容的使用寿命。双向主从同步功能为四输出系统提供均匀分布的相移,可进一步降低输入纹波并衰减系统噪声。
宽输入范围可支持3.3V,5V和12 V总线。精确的参考电压满足ASIC所需的精确电压,并可能降低输出电容要求。独立的PGOOD信号为系统监控和排序提供了灵活性。两个通道是独立控制的,每个软启动时间都是可编程的。实施电压模式控制以降低噪声灵敏度并确保低占空比转换。
Vin (Min) (V) |
Vin (Max) (V) |
Vout (Min) (V) |
Vout (Max) (V) |
Iout (Max) (A) |
Regulated Outputs (#) |
Number of Phases |
Switching Frequency (Min) (kHz) |
Switching Frequency (Max) (kHz) |
Iq (Typ) (mA) |
Features |
Duty Cycle (Max) (%) |
Operating Temperature Range (C) |
Rating |
Package Group |
Control Mode |
TPS40322 | TPS40422 |
3 | 4.5 |
20 | 20 |
0.6 | 0.6 |
5.6 | 5.6 |
60 | 60 |
2 | 2 |
2 | 2 |
100 | 200 |
1000 | 1000 |
6 | 18 |
Enable Frequency Synchronization Multiple Outputs Phase Interleaving Power Good Remote Sense | Dynamic Voltage Scaling Enable Frequency Synchronization Multiple Outputs PMBus Phase Interleaving Remote Sense |
95 | 90 |
-40 to 125 | -40 to 125 |
Catalog | Catalog |
VQFN | VQFN WQFN |
Voltage Mode | Voltage Mode |
