数据: 具有 DCS-Control™ 的 TPS6216x 3V 至 17V 1A 降压转换器 数据表 (Rev. E)
TPS6216x系列是一款简单易用的同步降压DC-DC转换器,针对高功率密度的应用进行了优化。该系列器件的<关键字典型值高达2.25MHz 3V至17V,非常适用于由锂离子或其他电池以及12V中间电源轨供电的系统。该器件的输出电压为0.9V至6V,支持高达1A的持续输出电流(使用100%占空比模式)。
此外,还可以通过配置使能引脚和开漏电源正常状态引脚实现电源排序。
在节能模式下,器件可根据输入电压(VIN)生成约17μA的静态电流。负载较小时可自动且无缝进入节能模式,同时该模式可保持整个负载范围内的高效率。该器件在关断模式下处于关断状态,期间的流耗低于2μA
此器件具有可调节输出电压和固定输出电压版本,采用2.00mm x 2.00mm 8引脚WSON封装(DSG)或3.00mm x 3.00mm 8引脚VSSOP封装(DGK)。
所有商标均为其各自所有者的财产。
Vin (Min) (V) |
Vin (Max) (V) |
Vout (Min) (V) |
Vout (Max) (V) |
Iout (Max) (A) |
Regulated Outputs (#) |
Switching Frequency (Min) (kHz) |
Switching Frequency (Max) (kHz) |
Iq (Typ) (mA) |
Features |
Control Mode |
Duty Cycle (Max) (%) |
Operating Temperature Range (C) |
Rating |
Package Group |
TPS62162 | TPS62132 | TPS62142 | TPS62152 | TPS62172 |
3 | 3 | 3 | 3 | 3 |
17 | 17 | 17 | 17 | 17 |
3.3 | 3.3 | 3.3 | 3.3 | 3.3 |
1 | 3 | 2 | 1 | 0.5 |
1 | 1 | 1 | 1 | 1 |
2250 | 1250 | 1250 | 1250 | 2250 |
2250 | 2500 | 2500 | 2500 | 2250 |
0.017 | 0.017 | 0.017 | 0.017 | 0.017 |
Enable Light Load Efficiency Output Discharge Power Good Synchronous Rectification Tracking Voltage Margining | Enable Light Load Efficiency Power Good Pre-Bias Start-Up Synchronous Rectification Tracking Voltage Margining | Enable Light Load Efficiency Output Discharge Power Good Synchronous Rectification Tracking Voltage Margining | Enable Light Load Efficiency Output Discharge Power Good Synchronous Rectification Tracking Voltage Margining | Enable Light Load Efficiency Output Discharge Power Good Synchronous Rectification Tracking Voltage Margining |
Constant on-time (COT) DCS-Control | Constant on-time (COT) DCS-Control | Constant on-time (COT) DCS-Control | Constant on-time (COT) DCS-Control | Constant on-time (COT) DCS-Control |
100 | 100 | 100 | 100 | 100 |
-40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 |
Catalog | Catalog | Catalog | Catalog | Catalog |
WSON | VQFN | VQFN | VQFN | WSON |
