TPS54628是一款自适应接通时间D-CAP2模式同步降压转换器.TPS54628可帮助系统设计人员通过一个成本有效,低组件TPS54628的主控制环路使用D-CAP2模式控制,此控制方式在无需外部补偿组件的情况下提供快速瞬态响应。 Eco-mode™使用TPS54628能够在较轻负载条件TPS54628的私有电路还使该器件可采用诸如高分子有机半导体固体电容器(POSCAP)或SP-CAP等低等效串联电阻(ESR)输出电容器以及超低ESR陶瓷电容器。该器件的下保持高效率。工作输入电压介于4.5V至18V VIN之间。输出电压可在0.76V与5.5V之间进行设定。该器件还特有一个可调软启动时间。 TPS54628采用8引脚DDA封装,并针对-40°C到85°C的工作温度范围内的运行而设计。
Vin (Min) (V) |
Vin (Max) (V) |
Vout (Min) (V) |
Vout (Max) (V) |
Iout (Max) (A) |
Regulated Outputs (#) |
Switching Frequency (Min) (kHz) |
Switching Frequency (Max) (kHz) |
Iq (Typ) (mA) |
Features |
Control Mode |
Duty Cycle (Max) (%) |
Operating Temperature Range (C) |
Rating |
Package Group |
TPS54628 | TPS54227 | TPS54228 | TPS54327 | TPS54328 | TPS54427 | TPS54428 | TPS54627 | TPS56428 | TPS56528 |
4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 |
18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 |
0.76 | 0.76 | 0.76 | 0.76 | 0.76 | 0.76 | 0.76 | 0.76 | 0.6 | 0.76 |
5.5 | 7 | 7 | 7 | 7 | 7 | 7 | 5.5 | 5.5 | 5.5 |
6 | 2 | 2 | 3 | 3 | 4 | 4 | 6 | 4 | 5 |
1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
650 | 700 | 700 | 700 | 700 | 650 | 650 | 650 | 650 | 650 |
0.95 | 0.8 | 0.8 | 0.8 | 0.8 | 0.95 | 0.95 | 0.95 | 0.25 | 0.25 |
Enable Light Load Efficiency Synchronous Rectification | Enable Synchronous Rectification | Enable Light Load Efficiency Synchronous Rectification | Enable Synchronous Rectification | Enable Light Load Efficiency Synchronous Rectification | Enable Synchronous Rectification | Enable Light Load Efficiency Synchronous Rectification | Enable Synchronous Rectification | Enable Light Load Efficiency Power Good Synchronous Rectification | Enable Light Load Efficiency Synchronous Rectification |
D-CAP2 | D-CAP2 | D-CAP2 | D-CAP2 | D-CAP2 | Current Mode | D-CAP2 | D-CAP2 | D-CAP2 | D-CAP2 |
85 | 90 | 90 | 90 | 90 | 95 | 95 | 85 | 85 | 85 |
-40 to 125 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 125 | -40 to 85 | -40 to 125 |
Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
SO PowerPAD | SO PowerPAD VSON | SO PowerPAD SOIC VSON | SO PowerPAD VSON | SO PowerPAD VSON | SO PowerPAD VSON | SO PowerPAD VSON | SO PowerPAD | SO PowerPAD VQFN | SO PowerPAD |
