数据: LMR14006 SIMPLE SWITCHER 40 V 600 mA Buck Regulator With High Efficiency Sleep Mode 数据表
LMR14006是一款PWM DC /DC降压(降压)稳压器。它具有4 V-40 V的宽输入范围,适用于从工业到汽车的各种应用,可用于来自未调节电源的功率调节。在休眠模式下,稳压器的待机电流为28μA,适用于电池操作系统。超低1μA电流可在关断模式下进一步延长电池寿命。工作频率固定为1.1 MHz(X版本)和2.1 MHz(Y版本),允许使用小型外部元件,同时仍能具有低输出纹波电压。软启动和补偿电路在内部实现,这些允许器件与最小化的外部元件一起使用。 LMR14006针对高达600 mA的负载电流进行了优化,具有0.765 V的典型反馈电压。该器件具有内置保护功能,如逐脉冲电流限制,热感应和功耗过大导致的关断。 LMR14006采用扁平TSOT-6L封装。
Vin (Min) (V) |
Vin (Max) (V) |
Vout (Min) (V) |
Vout (Max) (V) |
Iout (Max) (A) |
Regulated Outputs (#) |
Switching Frequency (Min) (kHz) |
Switching Frequency (Max) (kHz) |
Iq (Typ) (mA) |
Features |
Control Mode |
Duty Cycle (Max) (%) |
Operating Temperature Range (C) |
Rating |
Package Group |
LMR14006 | LMR14010A | LMR14020 | LMR14030 | LMR14050 | TPS560430 |
4 | 4 | 4 | 4 | 4 | 4 |
40 | 40 | 40 | 40 | 40 | 36 |
0.8 | 0.8 | 1 | 1 | 1 | 1 |
30 | 30 | 36 | 36 | 36 | 24 |
0.6 | 1 | 2 | 3.5 | 5 | 0.6 |
1 | 1 | 1 | 1 | 1 | 1 |
1100 | 550 | 200 | 200 | 200 | 1100 |
2100 | 850 | 2500 | 2500 | 2500 | 2100 |
0.028 | 0.03 | 0.04 | 0.04 | 0.04 | 0.08 |
Enable Light Load Efficiency Pre-Bias Start-Up UVLO Adjustable | Enable Light Load Efficiency Over Current Protection Pre-Bias Start-Up UVLO Fixed | Enable Frequency Synchronization Light Load Efficiency Power Good Pre-Bias Start-Up Tracking UVLO Adjustable | Enable Frequency Synchronization Light Load Efficiency Power Good Pre-Bias Start-Up Tracking UVLO Adjustable | Enable Frequency Synchronization Light Load Efficiency Power Good Pre-Bias Start-Up Tracking UVLO Adjustable | Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Over Current Protection Pre-Bias Start-Up Synchronous Rectification Tracking UVLO Adjustable |
Current Mode | Current Mode | Current Mode | Current Mode | Current Mode | Current Mode |
97 | 96 | 98 | 98 | 98 | 98 |
-40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 |
Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
SOT-23-THIN | SOT-23-THIN | SO PowerPAD | SO PowerPAD | SO PowerPAD | SOT-23 |
型号:LMR14006XDDCR 封装:SOT-23-THIN
品牌:TI 描述:降压型-40℃~+125℃@(TJ)1降压可调0.765V~38.4V 600mA 4V~40V 1.1MHz TSOT-23-6 DC-DC转换器ROHS
金额:¥2.58544
去购买型号:LMR14006YDDCR 封装:SOT23-6
品牌:TI 描述:功能类型:降压型 输出类型:可调 输入电压:4~40V 输出电压:765mV~38.4V 输出电流(最大值):600mA
金额:¥1.88552
去购买
