数据: TPS53647 4 相 D-CAP+ 降压控制器,具有 NVM 和 PMBus™ 接口,适用于 ASIC 电源和高电流负载点 数据表 (Rev. B)
TPS53647是一款高电流多相位降压控制器。该器件提供内置非易失性存储器(NVM)和PMBus接口。此款产品与NexFET功率级(CSD95372BQ5MC)兼容.TPS53647提供8位启动电压选择,输出电压范围为0.5V到2.5V,步长低至5mV,非常适合具备精确输出电压设置的高电流应用。具有D-CAP +架构等高级特性,支持下冲衰减(USR)和过冲衰减(OSR),可实现快速瞬态响应,最小的输出电容和高效率.TPS53647还提供新型相位交错策略和动态相位减少功能,可有效提升轻量载条件下的效率。此外,TPS53647支持PMBus通信接口,适用于电压,电流,功率,温度和故障条件遥测系统。部分配置可通过引脚设置或PMBus编程设定并存储在非易失性存储器中,这样可以减少外部组件的数量。
TPS53647采用节省空间,耐热增强型40引脚QFN封装,额定运行温度介于-40°C至125°C之间。
所有商标均为他们各自的主人。
Vin (Min) (V) |
Vin (Max) (V) |
Vout (Min) (V) |
Vout (Max) (V) |
Iout (Max) (A) |
Regulated Outputs (#) |
Number of Phases |
Switching Frequency (Min) (kHz) |
Switching Frequency (Max) (kHz) |
Iq (Typ) (mA) |
Features |
Duty Cycle (Max) (%) |
Operating Temperature Range (C) |
Rating |
Package Group |
Control Mode |
TPS53647 | TPS40422 | TPS40425 | TPS40428 | TPS53667 | TPS53681 |
4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 |
17 | 20 | 20 | 20 | 17 | 17 |
0.5 | 0.6 | 0.6 | 0.6 | 0.5 | 0.25 |
2.5 | 5.6 | 5 | 5 | 2.5 | 2.8125 |
240 | 60 | 40 | 40 | 420 | 300 |
1 | 2 | 2 | 2 | 1 | 2 |
4 | 2 | 2 | 2 | 6 | 8 |
300 | 200 | 200 | 200 | 300 | 300 |
1000 | 1000 | 1500 | 1500 | 1000 | 1000 |
8 | 18 | 18 | 18 | 6.1 | 13 |
Adjustable Current Limit Dynamic Voltage Scaling Enable Light Load Efficiency Output Discharge PMBus Phase Interleaving Power Good Pre-Bias Start-Up Remote Sense Synchronous Rectification UVLO Adjustable Voltage Margining | Dynamic Voltage Scaling Enable Frequency Synchronization Multiple Outputs PMBus Phase Interleaving Remote Sense | Adjustable Current Limit Dynamic Voltage Scaling Enable Frequency Synchronization Phase Interleaving Power Good Pre-Bias Start-Up Remote Sense Synchronous Rectification UVLO Adjustable Voltage Margining | Adjustable Current Limit Dynamic Voltage Scaling Enable Frequency Synchronization PMBus Phase Interleaving Power Good Pre-Bias Start-Up Remote Sense Synchronous Rectification UVLO Adjustable Voltage Margining | Adjustable Current Limit Dynamic Voltage Scaling Enable Light Load Efficiency PMBus Phase Interleaving Power Good Pre-Bias Start-Up Remote Sense Synchronous Rectification UVLO Adjustable Voltage Margining | Adjustable Current Limit Dynamic Voltage Scaling Enable Light Load Efficiency Multiple Outputs PMBus Phase Interleaving Power Good Pre-Bias Start-Up Remote Sense Synchronous Rectification UVLO Adjustable Voltage Margining |
50 | 90 | 46 | 46 | 50 | 50 |
-40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 |
Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
WQFN | VQFN WQFN | VQFN | VQFN | WQFN | WQFN |
D-CAP+ | Voltage Mode | Voltage Mode | Voltage Mode | D-CAP+ | D-CAP+ |
