数据: TPS56220x 采用 6 引脚 SOT-23 封装的 4.5V 至 17V 输入、2A 同步降压稳压器 数据表
TPS562201和TPS562208是采用SOT-23封装的简单易用型2A同步降压转换器。
此器件被优化为了使用尽可能少的外部组件即可运行,并且可以实现低待机电流。
这些开关模式电源(SMPS)器件采用D-CAP2模式控制,从而提供快速瞬态响应,并且在无需外部补偿组件的情况下支持诸如高分子聚合物等低等效串联电阻(ESR)输出电容器以及超低ESR陶瓷电容器。
TPS562201可在脉冲跳跃模式下运行,从而能在轻载运行期间保持高效率.TPS562201和TPS562208采用6引脚1.6mm×2.9mm SOT(DDC)封装,额定结温范围为-40°C至125°C。
所有商标均为其各自所有者的财产。
Vin (Min) (V) |
Vin (Max) (V) |
Vout (Min) (V) |
Vout (Max) (V) |
Iout (Max) (A) |
Regulated Outputs (#) |
Switching Frequency (Min) (kHz) |
Switching Frequency (Max) (kHz) |
Iq (Typ) (mA) |
Features |
Control Mode |
Duty Cycle (Max) (%) |
Operating Temperature Range (C) |
Rating |
Package Group |
TPS562201 | TPS563201 | TPS564201 | TPS564208 | TPS565201 | TPS565208 |
4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 |
17 | 17 | 17 | 17 | 17 | 17 |
0.76 | 0.76 | 0.76 | 0.76 | 0.76 | 0.76 |
7 | 7 | 7 | 7 | 7 | 7 |
2 | 3 | 4 | 4 | 5 | 5 |
1 | 1 | 1 | 1 | 1 | 1 |
580 | 580 | 500 | 500 | 400 | 500 |
580 | 580 | 600 | 600 | 600 | 500 |
0.4 | 0.4 | 0.4 | 0.4 | 0.4 | 0.6 |
Enable Light Load Efficiency Synchronous Rectification | Enable Light Load Efficiency Synchronous Rectification | Enable Light Load Efficiency Synchronous Rectification | Enable Forced Pulse Width Modulation (FPWM) Mode Synchronous Rectification | Enable Light Load Efficiency Synchronous Rectification | Enable Forced Pulse Width Modulation (FPWM) Mode Synchronous Rectification |
D-CAP2 | D-CAP2 | D-CAP2 | D-CAP2 | D-CAP2 | D-CAP2 |
80 | 80 | 80 | 80 | 80 | 80 |
-40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 |
Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
SOT-23-THIN | SOT-23-THIN | SOT-23-THIN | SOT-23-THIN | SOT-23-THIN | SOT-23-THIN |
型号:TPS562201DDCR 封装:SOT-23-THIN
品牌:TI 描述:功能类型:降压型 输出类型:可调 输入电压:4.5~17V 输出电压:0.76~7V 输出电流(最大值):2A
金额:¥0.19000
去购买
