TPS62135和TPS621351是高效且易于使用的同步降压DC-DC转换器,基于DCS-控制™拓扑技术。器件具有3V至17V的宽输入电压范围,非常适合由多节锂离子电池以及12V中间电源轨供电的应用。该器件提供图4A连续输出电流.TPS62135可以在轻载时自动进入节能模式,从而可在整个负载范围内保持高效率。因此,器件非常适合要求联网待机性能的应用,例如,超低功耗计算机。如果将MODE引脚设置为低电平,那么器件的开关频率会基于输入输出电压自动调整。该技术称为自动效率提高(AEE™),可以在整个运行范围内保持高转换效率。器件可以在PWM模式下提供1%的输出电压精度,因此可实现具有高输出电压精度的电源设计。
< p>器件的典型静态电流为18μA。在关断模式下,器件电流典型值为1μA,输出主动放电(仅适用于TPS62135,TP S621351的输出电压放电功能被禁用)。TPS62135作为一个可调版本提供,采用3mm x 2mm VQFN封装。
所有商标均为其各自所有者的财产。
Vin (Min) (V) |
Vin (Max) (V) |
Vout (Min) (V) |
Vout (Max) (V) |
Iout (Max) (A) |
Regulated Outputs (#) |
Switching Frequency (Min) (kHz) |
Switching Frequency (Max) (kHz) |
Iq (Typ) (mA) |
Features |
Control Mode |
Duty Cycle (Max) (%) |
Operating Temperature Range (C) |
Rating |
Package Group |
TPS62135 | TPS621351 | TPS62136 | TPS62140 | TPS62147 | TPS62148 |
3 | 3 | 3 | 3 | 3 | 3 |
17 | 17 | 17 | 17 | 17 | 17 |
0.8 | 0.8 | 0.8 | 0.9 | 0.8 | 0.8 |
12 | 12 | 12 | 6.3 | 12 | 12 |
4 | 4 | 4 | 2 | 2 | 2 |
1 | 1 | 1 | 1 | 1 | 1 |
2500 | 2500 | 1000 | 1250 | 1250 | 1250 |
2500 | 2500 | 1000 | 2500 | 2500 | 2500 |
0.018 | 0.018 | 0.018 | 0.017 | 0.018 | 0.018 |
Enable Light Load Efficiency Output Discharge Power Good Pre-Bias Start-Up Synchronous Rectification Tracking UVLO Fixed VID: other | Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Over Current Protection Power Good Pre-Bias Start-Up Synchronous Rectification Tracking UVLO Fixed VID: other | Dynamic Voltage Scaling Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Output Discharge Over Current Protection Power Good Pre-Bias Start-Up Synchronous Rectification Tracking UVLO Fixed VID: 2-bit | Enable Light Load Efficiency Output Discharge Over Current Protection Power Good Pre-Bias Start-Up Synchronous Rectification Tracking UVLO Fixed Voltage Margining | Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Output Discharge Over Current Protection Power Good Pre-Bias Start-Up Synchronous Rectification Tracking UVLO Adjustable | Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Output Discharge Over Current Protection Power Good Pre-Bias Start-Up Synchronous Rectification Tracking UVLO Adjustable |
Constant on-time (COT) DCS-Control | Constant on-time (COT) DCS-Control | Constant on-time (COT) DCS-Control | Constant on-time (COT) DCS-Control | DCS-Control | DCS-Control |
100 | 100 | 100 | 100 | 100 | 100 |
-40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 |
Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
VQFN-HR | VQFN-HR | VQFN-HR | VQFN | VQFN-HR | VQFN-HR |
型号:TPS62135RGXR 封装:VQFN11_3X2MM_EP
品牌:TI 描述:功能类型:降压型 输出类型:可调 输入电压:3~17V 输出电压:0.8~12V 输出电流(最大值):4A
金额:¥88.55735
去购买
