数据: TPS546C23 具有 PMBus 的 4.5V 至 18V、35A 可堆叠同步降压转换器 数据表 (Rev. B)
TPS546C23器件是采用5mm×7mm封装而符合PMBus 1.3规范的非隔离式DC-DC转换器,集成了FET,能够在高频下运行并输出35A电流。两个TPS546C23器件可以并联,以便产生高达70A的负载电流。通过针对少量功率级电流进行采样实现电流感测,与器件温度无关。集成NexFET功率级和优化驱动器提供高频低损耗开关功能,可实现超高密度电源解决方案.PMBus接口通过VOUT_COMMAND启用AVS功能,同时支持灵活转换器配置以及关键参数监控功能(包括输出电压,电流和内部芯片温度监控)。对故障条件的响应可设为重启,锁存或忽略,具体取决于系统要求。
All trademarks are the property of their respective owners.
Vin (Min) (V) |
Vin (Max) (V) |
Vout (Min) (V) |
Vout (Max) (V) |
Iout (Max) (A) |
Regulated Outputs (#) |
Switching Frequency (Min) (kHz) |
Switching Frequency (Max) (kHz) |
Iq (Typ) (mA) |
Features |
Control Mode |
Duty Cycle (Max) (%) |
Operating Temperature Range (C) |
Rating |
Package Group |
TPS546C23 |
4.5 |
18 |
0.35 |
5.5 |
35 |
1 |
200 |
1000 |
7.7 |
Adjustable Current Limit Dynamic Voltage Scaling Frequency Synchronization PMBus Phase Interleaving Power Good Remote Sense Synchronous Rectification Tracking UVLO Adjustable Voltage Margining |
Voltage Mode |
100 |
-40 to 125 |
Catalog |
LQFN-CLIP |
