数据: TPS61170 1.2-A High-Voltage Boost Converter in 2-mm x 2-mm2 QFN Package 数据表
TPS61170是一款单片高压开关稳压器,集成了1.2 A,40 V功率MOSFET。该器件可配置为多种标准开关稳压器拓扑结构,包括升压和SEPIC。该器件具有宽输入电压范围,可支持具有多节电池输入电压或稳压5 V,12 V电源轨的应用。
TPS61170工作在1.2 MHz开关频率,允许使用薄型电感器和低值陶瓷输入和输出电容器。外部环路补偿组件为用户提供了优化环路补偿和瞬态响应的灵活性。该器件具有内置保护功能,如逐脉冲过流限制,软启动和热关断。
FB引脚调节至1.229 V的参考电压。参考电压可以是通过CTRL引脚使用1线数字接口(Easyscale™协议)降低。或者,可以将脉冲宽度调制(PWM)信号施加到CTRL引脚。信号的占空比按比例降低反馈参考电压。
TPS61170采用6引脚2 mm×2 mm QFN封装,可提供紧凑的电源解决方案。
Vin (Min) (V) |
Vin (Max) (V) |
Vout (Min) (V) |
Vout (Max) (V) |
Switch Current Limit (Typ) (A) |
Regulated Outputs (#) |
Switching Frequency (Min) (kHz) |
Switching Frequency (Max) (kHz) |
Iq (Typ) (mA) |
Features |
Duty Cycle (Max) (%) |
Operating Temperature Range (C) |
Rating |
Package Group |
TPS61170 | LM2621 | LM2623 | LM27313 | LM2733 | TLV61046A | TPS61040 | TPS61087 |
3 | 1.2 | 0.8 | 2.7 | 2.7 | 1.8 | 1.8 | 2.5 |
18 | 14 | 14 | 14 | 14 | 5.5 | 6 | 6 |
3 | 1.24 | 1.24 | 4 | 3 | 3.3 | 1.8 | 3 |
38 | 14 | 14 | 28 | 40 | 28 | 28 | 18.5 |
1.2 | 2.85 | 2.85 | 1.25 | 1.5 | 0.9 | 0.4 | 4 |
1 | 1 | 1 | 1 | 1 | 1 | 1 | |
1000 | 300 | 1150 | 400 | 850 | 900 | ||
1200 | 2000 | 2000 | 1900 | 1850 | 1250 | 1000 | 1500 |
2.3 | 0.08 | 0.08 | 2.1 | 1.1 | 0.11 | 0.028 | 0.075 |
Enable Light Load Efficiency | Enable | Enable | Enable Light Load Efficiency | Enable Light Load Efficiency | Enable Light Load Efficiency Load Disconnect | Enable | Enable Power Good |
93 | 90 | 88 | 96 | 88 | 90 | ||
-40 to 85 | -40 to 85 | -40 to 85 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 85 | -40 to 85 |
Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
WSON | VSSOP | VSSOP WSON | SOT-23 | SOT-23 | SOT-23 | SOT-23 SOT-23-THIN WSON | VSON WSON |
金额:¥21.92747
去购买型号:TPS61170DRVR 封装:WSON6_2X2MM_EP
品牌:TI 描述:降压-升压型1 3V~38V 3V~18V 1.2MHz WSON6_2X2MM_EP DC-DC转换器ROHS
金额:¥1.16630
去购买
