数据: LM2733 0.6 and 1.6-MHz Boost Converters With 40-V Internal FET Switch in SOT-23 数据表
LM2733开关稳压器是电流模式升压转换器,工作固定频率为1.6 MHz(?? X ??选项)和600 kHz(?? Y? ?\ x9Doption)。
使用SOT-23封装,通过内部1-A开关的最小功率损耗,以及使用小型电感器和电容器,可实现业界最高的功率密度。 40 V内部开关使这些解决方案非常适合升压至16 V或更高的电压。
这些器件具有逻辑电平关断引脚,可用于降低静态电流并延长电池寿命。 /p>
通过逐周期电流限制和热关断提供保护。内部补偿简化了设计并减少了元件数量。
Vin (Min) (V) |
Vin (Max) (V) |
Vout (Min) (V) |
Vout (Max) (V) |
Switch Current Limit (Typ) (A) |
Regulated Outputs (#) |
Switching Frequency (Min) (kHz) |
Switching Frequency (Max) (kHz) |
Iq (Typ) (mA) |
Features |
Duty Cycle (Max) (%) |
Operating Temperature Range (C) |
Rating |
Package Group |
LM2733 | LM2621 | LM2623 | LM2731 | LM27313 | LM2735 | LM2735-Q1 | TLV61046A | TPS61040 | TPS61087 | TPS61170 |
2.7 | 1.2 | 0.8 | 2.7 | 2.7 | 2.7 | 2.7 | 1.8 | 1.8 | 2.5 | 3 |
14 | 14 | 14 | 14 | 14 | 5.5 | 5.5 | 5.5 | 6 | 6 | 18 |
3 | 1.24 | 1.24 | 1.23 | 4 | 3 | 3 | 3.3 | 1.8 | 3 | 3 |
40 | 14 | 14 | 22 | 28 | 24 | 24 | 28 | 28 | 18.5 | 38 |
1.5 | 2.85 | 2.85 | 1.5 | 1.25 | 2.25 | 2.25 | 0.9 | 0.4 | 4 | 1.2 |
1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | |
400 | 300 | 1150 | 850 | 900 | 1000 | |||||
1850 | 2000 | 2000 | 1900 | 1250 | 1000 | 1500 | 1200 | |||
1.1 | 0.08 | 0.08 | 2 | 2.1 | 7 | 7 | 0.11 | 0.028 | 0.075 | 2.3 |
Enable Light Load Efficiency | Enable | Enable | Enable Light Load Efficiency | Enable | Enable | Enable Light Load Efficiency Load Disconnect | Enable | Enable Power Good | Enable Light Load Efficiency | |
96 | 90 | 88 | 88 | 90 | 93 | |||||
-40 to 125 | -40 to 85 | -40 to 85 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 85 | -40 to 85 | -40 to 85 |
Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Automotive | Catalog | Catalog | Catalog | Catalog |
SOT-23 | VSSOP | VSSOP WSON | SOT-23 | SOT-23 | MSOP-PowerPAD SOT-23 WSON | SOT-23 WSON | SOT-23 | SOT-23 SOT-23-THIN WSON | VSON WSON | WSON |
型号:LM2733XMF/NOPB 封装:SOT23-5
品牌:TI 描述:功能类型:升压型 输出类型:可调 输入电压:2.7~14V 输出电压:3~40V 输出电流(最大值):1A
金额:¥2.80014
去购买型号:LM2733YMF/NOPB 封装:SOT23-5
品牌:TI 描述:升压转换器型号-40℃~+125℃@(TJ)1升压可调2.7V~40V 1A 2.7V~14V 600kHz SOT-23-5 DC-DC转换器ROHS
金额:¥7.09979
去购买金额:¥2.28900
去购买
