数据: 用于 1-4 节串联锂离子电池组的 bq4050 CEDV 电量测量仪表和保护解决方案 数据表 (Rev. B)
德州仪器(TI)的bq4050器件采用补偿放电终止电压(CEDV)技术,是一款高度集成的高精度1-4节电池电量
bq4050器件提供一个基于电池组的完全集成式解决方案,该解决方案具备闪存可编程的定制精简指令集CPU(RISC),安全保护以及身份验证,适用于锂离子和锂聚合物电池组。
bq4050电量测量仪表通过一个与SMBus兼容的接口进行通信,并将超低功耗的高速TI bqBMP处理器,高精度模拟测量功能,集成式闪存存储器,一组外设和通信端口,N通道FET驱动以及SHA-1身份验证变换响应器,融合为一个完整的高性能电池管理解决方案方案。
所有商标均为其各自所有者的财产。
Number of Series Cells |
Cell Chemistry |
Battery Capacity (Max) (mAh) |
Communication Interface |
Battery Capacity (Min) (mAh) |
External Capacity Indication |
Implementation |
Gas Gauge Algorithm |
Cell Balancing |
Features |
Operating Temperature Range (C) |
Pin/Package |
BQ4050 | BQ27542-G1 | BQ27750 | BQ28Z610 | BQ40Z50-R1 | BQ40Z50-R2 | BQ78Z100 |
2-4 Cells Single Cell | Single Cell | Single Cell | 1-2 Cells | 2-4 Cells Single Cell | 2-4 Cells Single Cell | 1-2 Cells |
Li-Ion/Li-Polymer LiFePO4 | Li-Ion/Li-Polymer | Li-Ion/Li-Polymer LiFePO4 | Li-Ion/Li-Polymer | Li-Ion/Li-Polymer LiFePO4 | Li-Ion/Li-Polymer LiFePO4 | Li-Ion/Li-Polymer |
29000 | 32000 | 14000 | 14000 | 29000 | 29000 | 14000 |
SMBus | HDQ I2C | I2C | I2C | SMBus | SMBus | HDQ |
500 | 100 | 100 | 100 | 100 | 500 | 100 |
LED | None | None | None | LED | LED | None |
Pack | Pack | Pack | Pack | Pack | Pack | Pack |
CEDV | Impedance Track | Impedance Track | Impedance Track | Impedance Track | Impedance Track | Impedance Track |
External Internal | N/A | N/A | External Internal | External Internal | External Internal | External Internal |
Cell Balancing Integrated Protector SHA-1 Authentication | SHA-1 Authentication | Accumulated Coulomb Count Battery Management Unit Integrated Protector SHA-1 Authentication | Battery Management Unit Cell Balancing Integrated Protector SHA-1 Authentication | Cell Balancing Integrated Protector SHA-1 Authentication Turbo Mode | Integrated Protector SHA-1 Authentication Turbo Mode | Cell Balancing Integrated Protector SHA-1 Authentication |
-40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 |
32VQFN | 12SON | 12SON | 12SON | 32VQFN | 32VQFN | 12SON |
