数据: bq78350-R1 CEDV 锂离子电量监测计和电池管理控制器(与 bq769x0 电池监控 AFE 配套) 数据表 (Rev. A)
德州仪器(TI)bq78350-R1锂离子和磷酸铁锂电池管理控制器与bq769x0系列模拟前端(AFE)保护器件配套,可提供全套电池管理系统(BMS)子系统,有助于加快产品开发,缩短上市时间。
bq78350-R1控制器和bq769x0 AFE支持3节到15节电池应用.bq78350-R1器件提供了精确的电量监测计和健康状况(SoH)监控器,还提供了电池平衡功能以及整套电压,电流和温度保护特性。
bq78350-R1器件提供了用于电量报告的可选LED或LCD显示配置。它还可通过SMBus 1.1接口传输数据。电池历史记录和诊断数据也保存在器件的非易失性存储器中,并且可通过同一接口获取。
所有商标均为其所有权各自所有者。
Number of Series Cells |
Cell Chemistry |
Battery Capacity (Max) (mAh) |
Communication Interface |
Battery Capacity (Min) (mAh) |
External Capacity Indication |
Implementation |
Gas Gauge Algorithm |
Cell Balancing |
Features |
Operating Temperature Range (C) |
Pin/Package |
BQ78350-R1 | BQ27510-G3 | BQ27542-G1 | BQ34110 | BQ34Z100-G1 | BQ40Z50-R1 | BQ78Z100 |
>4 Cells | Single Cell | Single Cell | 2-4 Cells >4 Cells Single Cell | 2-4 Cells >4 Cells Single Cell | 2-4 Cells Single Cell | 1-2 Cells |
Li-Ion/Li-Polymer LiFePO4 | Li-Ion/Li-Polymer | Li-Ion/Li-Polymer | Lead Acid Li-Ion/Li-Polymer LiFePO4 NiCd NiMH | Lead Acid Li-Ion/Li-Polymer LiFePO4 NiCd NiMH | Li-Ion/Li-Polymer LiFePO4 | Li-Ion/Li-Polymer |
320000 | 16000 | 32000 | 29000 | 29000 | 29000 | 14000 |
I2C SMBus | I2C | HDQ I2C | I2C | HDQ I2C | SMBus | HDQ |
100 | 300 | 100 | 100 | 100 | 100 | 100 |
LCD LED SOC | None | None | None | LED | LED | None |
Pack | System | Pack | Pack System | Pack System | Pack | Pack |
CEDV | Impedance Track | Impedance Track | CEDV | Impedance Track | Impedance Track | Impedance Track |
External Internal | N/A | N/A | N/A | N/A | External Internal | External Internal |
Cell Balancing Integrated Protector SHA-1 Authentication | N/A | SHA-1 Authentication | Accumulated Coulomb Count End of Service SHA-1 Authentication | SHA-1 Authentication | Cell Balancing Integrated Protector SHA-1 Authentication Turbo Mode | Cell Balancing Integrated Protector SHA-1 Authentication |
-40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 |
30TSSOP | 12SON | 12SON | 14TSSOP | 14TSSOP | 32VQFN | 12SON |
