数据: TPS53627适用于 VR13 CPU VCORE 和 DDR 内存的 两相 D-CAP+™ 降压控制器 数据表
TPS53627器件是兼容VR13 SVID的无驱动器同步降压控制器。高级控制特性(例如具有重叠脉冲的D-CAP +™架构)支持下冲衰减(USR)和过冲衰减(OSR),可提供快速瞬态响应,最低输出电容和高效率。该器件还支持在CCM和DCM运行情况下进行单相运行,从而提高轻负载情况下的效率。该器件集成了一整套VR13 I /O特性,包括VR_READY(PGOOD), ALERT 和 VR_HOT .SVID接口地址允许在00h到07h的时间范围内进行编程。输出电压转换率的可调节控制可编程为高达20mV /uS。
与TI NexFET™功率级
TPS53627器件采用节省空间的热增强型32引脚VQFN封装,可在-40°C到+ 105° C温度下运行。
所有商标均为其各自所有者的财产。
Vin (Min) (V) |
Vin (Max) (V) |
Vout (Min) (V) |
Vout (Max) (V) |
Iout (Max) (A) |
Platform |
Number of Phases |
Regulated Outputs (#) |
Switching Frequency (Min) (kHz) |
Switching Frequency (Max) (kHz) |
Features |
Iq (Typ) (mA) |
Operating Temperature Range (C) |
Package Group |
Rating |
TPS53627 | TPS53626 |
4.5 | 4.5 |
28 | 28 |
0.5 | 0.25 |
3.04 | 1.52 |
95 | 70 |
VR13 | VR13 |
2 | 2 |
1 | 1 |
300 | 300 |
1000 | 1000 |
Adjustable Current Limit Dynamic Voltage Scaling Enable Light Load Efficiency Output Discharge Phase Interleaving Power Good Pre-Bias Start-Up Remote Sense SVID Synchronous Rectification | Adjustable Current Limit Dynamic Voltage Scaling Enable Light Load Efficiency Output Discharge Phase Interleaving Power Good Pre-Bias Start-Up Remote Sense SVID Synchronous Rectification |
3.5 | 3.5 |
-40 to 105 | -40 to 105 |
VQFN | VQFN |
Catalog | Catalog |
