LM25141-Q1是一款同步降压转换器,适用于高电压宽输入电压降压稳压器应用。控制方法为峰值电流模式控制。电流模式控制可提供内部线路前馈,逐周期电流限制和简化的环路补偿.LM25141-Q1具有压摆率控制功能,能够轻松满足CISPR和汽车EMI要求。
LM25141 -Q1有两种开关频率可选:2.2MHz和440kHz。栅极驱动器具有压摆率控制功能,可通过调整来降低EMI。
在轻负载或无负载条件下,LM25141- Q1通过以跳周期模式运行来提升低功耗效率.LM25141-Q1具备能够自动切换至外部偏置电源的高电压偏置稳压器,可以降低来自V IN 的I < sub> Q 电流。其他功能包括频率同步,逐周期电流限制,持续过载情况下的间断模式故障保护以及电源正常输出。
所有商标均为其各自所有者的财产。
Vin (Min) (V) |
Vin (Max) (V) |
Vout (Min) (V) |
Vout (Max) (V) |
Iout (Max) (A) |
Regulated Outputs (#) |
Number of Phases |
Switching Frequency (Min) (kHz) |
Switching Frequency (Max) (kHz) |
Iq (Typ) (mA) |
Features |
Duty Cycle (Max) (%) |
Operating Temperature Range (C) |
Rating |
Package Group |
Control Mode |
LM25141-Q1 | LM25117-Q1 | LM5117-Q1 | TPS40170-Q1 |
3.8 | 4.5 | 5.5 | 4.5 |
42 | 42 | 65 | 60 |
1.5 | 0.8 | 0.8 | 0.6 |
15 | 41 | 62 | 57 |
20 | 20 | 20 | 20 |
1 | 1 | 1 | 1 |
1 | 1 | 1 | 1 |
350 | 50 | 50 | 100 |
2600 | 750 | 750 | 600 |
0.035 | 4.8 | 4.8 | 4.5 |
Adjustable Current Limit Enable Frequency Synchronization Light Load Efficiency Power Good Pre-Bias Start-Up Spread Spectrum Synchronous Rectification UVLO Fixed | Adjustable Current Limit Enable Frequency Synchronization Light Load Efficiency Synchronous Rectification Tracking UVLO Adjustable | Adjustable Current Limit Enable Frequency Synchronization Light Load Efficiency Synchronous Rectification Tracking UVLO Adjustable | Adjustable Current Limit Enable Frequency Synchronization Power Good Pre-Bias Start-Up Synchronous Rectification Tracking UVLO Adjustable |
99 | 98 | 98 | 95 |
-40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 |
Automotive | Automotive | Automotive | Automotive |
VQFN | HTSSOP WQFN | HTSSOP WQFN | VQFN |
Current Mode | Current Mode | Current Mode | Voltage Mode |
