TLV61046A是一款高度集成型升压转换器,专为PMOLED面板,LCD偏置电源和传感器模块等应用而设计.TLV61046A集成了30V电源开关,输入至输出的隔离开关以及整流器二极管。该器件可将来自一节锂离子电池或两节碱性电池(串联)的输入电压转换成高达28V的输出电压。
TLV61046A的工作开关频率为1.0MHz。通过将TLV61046A的FB引脚和VIN引脚相连,可将其默认内部输出电压设置为12V。因此,只需要三个外部组件即可获得12V输出电压.TLV61046A的开关限流典型值为980mA。它具有7ms内置软启动时间,从而能够降低浪涌电流.TLV61046A处于关断模式时,隔离开关会将输出与输入断开以最大限度降低泄漏电流.TLV61046A还具有输出短路保护,输出过压保护和热关断。
TLV61046A采用6引脚,3mm x 3mm SOT 23-6封装。
所有商标均为其各自所有者的财产。
Vin (Min) (V) |
Vin (Max) (V) |
Vout (Min) (V) |
Vout (Max) (V) |
Switch Current Limit (Typ) (A) |
Regulated Outputs (#) |
Switching Frequency (Min) (kHz) |
Switching Frequency (Max) (kHz) |
Iq (Typ) (mA) |
Features |
Duty Cycle (Max) (%) |
Operating Temperature Range (C) |
Rating |
Package Group |
TLV61046A | LM2621 | LM2623 | LM27313 | LM2733 | TPS61040 | TPS61041 | TPS61046 | TPS61087 | TPS61093 | TPS61170 |
1.8 | 1.2 | 0.8 | 2.7 | 2.7 | 1.8 | 1.8 | 1.8 | 2.5 | 1.6 | 3 |
5.5 | 14 | 14 | 14 | 14 | 6 | 6 | 5.5 | 6 | 6 | 18 |
3.3 | 1.24 | 1.24 | 4 | 3 | 1.8 | 1.8 | 4.5 | 3 | 1.7 | 3 |
28 | 14 | 14 | 28 | 40 | 28 | 28 | 28 | 18.5 | 17 | 38 |
0.9 | 2.85 | 2.85 | 1.25 | 1.5 | 0.4 | 0.25 | 0.9 | 4 | 1.1 | 1.2 |
1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | ||
850 | 300 | 1150 | 400 | 850 | 900 | 1000 | 1000 | |||
1250 | 2000 | 2000 | 1900 | 1850 | 1000 | 1000 | 1250 | 1500 | 1400 | 1200 |
0.11 | 0.08 | 0.08 | 2.1 | 1.1 | 0.028 | 0.028 | 0.11 | 0.075 | 0.9 | 2.3 |
Enable Light Load Efficiency Load Disconnect | Enable | Enable | Enable Light Load Efficiency | Enable Light Load Efficiency | Enable | Enable | Enable Light Load Efficiency Load Disconnect | Enable Power Good | Enable Output Discharge | Enable Light Load Efficiency |
90 | 88 | 96 | 88 | 88 | 90 | 90 | 93 | 93 | ||
-40 to 125 | -40 to 85 | -40 to 85 | -40 to 125 | -40 to 125 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 |
Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
SOT-23 | VSSOP | VSSOP WSON | SOT-23 | SOT-23 | SOT-23 SOT-23-THIN WSON | SOT-23 WSON | DSBGA | VSON WSON | SON | WSON |
型号:TLV61046ADBVR 封装:SOT23-6
品牌:TI 描述:DC-DC开关控制芯片 1 Boost Adjustable 1.8V~5.5V 1.05MHz SOT23-6
金额:¥3.83160
去购买
