TPS6123x器件系列是一款采用紧凑解决方案尺寸的高效同步升压转换器。它针对由单节锂离子电池或3.3V稳压电源轨供电的产品进行了优化。集成电路(IC)中集成了一个5A开关,并且能够在由3.3V输入电源供电,输出电压为5V时传送高达2.1A的输出电流。此器件基于准恒定接TPS61230和TPS61231通过一个外部电阻分压器提供可调输出电压,而TPS61232提供5V通电时模的固定输出电压。
轻负载期间,TPS6123x自动进入省电模式,以最低静态电流实现最大效率。在关断期间,负载完全从输入上断开,并且输入流耗减少至1.5μA(典型值)。此器件集成一个精密低功率EN比较器.EN阀值以及使能比较器的滞后可由外部电阻器调节,并且支持应用专用系统加电和断电要求。还内置了其他诸如输出过压保护,热关断保护和电源正常输出等特性。
此器件采用3mm x 3mm x 0.9mm VSON封装。
所有商标是他们各自所有者的财产。
Vin (Min) (V) |
Vin (Max) (V) |
Vout (Min) (V) |
Vout (Max) (V) |
Switch Current Limit (Typ) (A) |
Regulated Outputs (#) |
Switching Frequency (Min) (kHz) |
Switching Frequency (Max) (kHz) |
Iq (Typ) (mA) |
Features |
Duty Cycle (Max) (%) |
Operating Temperature Range (C) |
Rating |
Package Group |
TPS61232 | TPS61230 | TPS61230A | TPS61235P | TPS61236P |
2.3 | 2.3 | 2.5 | 2.3 | 2.3 |
5.5 | 5.5 | 4.5 | 5.5 | 5.5 |
5 | 2.5 | 2.5 | 5.1 | 2.9 |
5 | 5.5 | 5.5 | 5.1 | 5.5 |
5 | 5 | 6 | 8 | 8 |
1 | 1 | 1 | 1 | 1 |
1150 | 750 | 750 | ||
2000 | 2000 | 1150 | 1250 | 1250 |
0.035 | 0.035 | 0.025 | 0.01 | 0.01 |
Enable Light Load Efficiency Load Disconnect Power Good Synchronous Rectification | Enable Light Load Efficiency Load Disconnect Power Good Synchronous Rectification | Enable Light Load Efficiency Load Disconnect Synchronous Rectification | Enable Light Load Efficiency Synchronous Rectification | Enable Light Load Efficiency Synchronous Rectification |
90 | 90 | 90 | 90 | 90 |
-40 to 85 | -40 to 85 | -40 to 125 | -40 to 85 | -40 to 85 |
Catalog | Catalog | Catalog | Catalog | Catalog |
VSON | VSON | VQFN-HR | VQFN-HR | VQFN-HR |
