适用于低功耗应用的TPS61256xC器件为电池供电类便携式优化提供至2.65V)的高达800mA的负载电流,并且允许使用低成本芯片电感器和电容器。
借助2.3V-5.5V的宽输入电压范围,该器件支持由各种电压的锂离子电池进行供电的应用。可提供3.15V到5.0V之间的不同固定电压输出版本。
TPS61256xC在3.5MHz的调节开关频率下运行,在轻负载电流情况下会进入省电模式,以便在整个负载电流范围内保持高效率.PFM模式可在轻负载工作时将静态电流降至37μA(典型值),从而可延长电池使用寿命。
此外,TPS61256xC器件还可通过将EN拉至低电平来支持直通模式。在这种模式下,输出电压跟随输入电压变化,由电感器和高侧FET的电阻来降低电压。
TPS61256xC最大限度地减少了外部组件的数量,因此拥有非常小巧的解决方案尺寸。为了实现小解决方案尺寸,它允许使用小型电感器和输入电容器。
所有商标均为其各自所有者的财产。
Vin (Min) (V) |
Vin (Max) (V) |
Vout (Min) (V) |
Vout (Max) (V) |
Switch Current Limit (Typ) (A) |
Regulated Outputs (#) |
Switching Frequency (Min) (kHz) |
Switching Frequency (Max) (kHz) |
Iq (Typ) (mA) |
Features |
Duty Cycle (Max) (%) |
Operating Temperature Range (C) |
Rating |
Package Group |
TPS612562C | TPS612564C | TPS61256C | TPS61253 | TPS61254 | TPS61256 | TPS61256A | TPS61258 | TPS61259 | TPS612592 |
2.5 | 2.5 | 2.5 | 2.65 | 2.5 | 2.5 | 2.5 | 2.65 | ||
4.85 | 4.85 | 4.85 | 4.85 | 4.35 | 4.85 | 5.5 | 4.85 | ||
5.2 | 5.4 | 5 | 5 | 4.5 | 5 | 5 | 4.5 | 5.1 | 5.2 |
2.15 | 2.15 | 2.15 | 3.6 | 2.15 | 2.15 | 2.4 | 3.6 | 3.6 | 3.6 |
1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
3500 | 3500 | 3500 | 3500 | 3500 | 3500 | 3500 | |||
3500 | 3500 | 3500 | 3500 | 3500 | 3500 | 3500 | 3500 | ||
0.02 | 0.02 | 0.02 | 0.02 | 0.023 | 0.02 | 0.033 | 0.02 | 0.02 | 0.02 |
Enable Light Load Efficiency Synchronous Rectification | Enable Light Load Efficiency Synchronous Rectification | Enable Light Load Efficiency Synchronous Rectification | Enable Light Load Efficiency Load Disconnect | Enable Light Load Efficiency Load Disconnect | Enable Light Load Efficiency Load Disconnect | Enable Light Load Efficiency Load Disconnect Synchronous Rectification | Enable Light Load Efficiency Load Disconnect | Enable Light Load Efficiency Load Disconnect | Enable Light Load Efficiency Load Disconnect |
100 | 100 | 100 | 90 | 100 | 90 | 90 | |||
-40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 |
Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
DSBGA | DSBGA | DSBGA | DSBGA | DSBGA | DSBGA | DSBGA | DSBGA | DSBGA | DSBGA |
