TPS63020-Q1器件是一款电源解决方案,广泛应用于由2-3节碱性电池,镍镉(NiCd)电池,镍氢(NiMH)电池以及单节锂离子电池或锂聚合物电池供电的产品。当使用单节锂离子电池或锂聚合物电池供电时,该器件提供高达3A的输出电流并可对电池进行放电,使其升压/降压转换器基于一个频率固定的脉宽调制(PWM)控制器。该控制器可通过同步整流实现效率最大化。在其载电流较低。的情况下,该转换器会进入节能模式,以在宽负载电流范围内保持高效率。禁用省电模式则会强制转换器以固定开关频率运行。开关的最大平均电流为4A(典型值)。输出电压可通过外部电阻分频器进行编程。转换器可被禁用以最大限度地减少电池消耗。在该机器采用3mm×4mm 14引脚VSON电源PAD封装(DSJ)。
所有商标均为其各自所有者的财产。
Topology |
Vin (Min) (V) |
Vin (Max) (V) |
Vout (Min) (V) |
Vout (Max) (V) |
Switch Current Limit (Typ) (A) |
Duty Cycle (Max) (%) |
Switching Frequency (Min) (kHz) |
Switching Frequency (Max) (kHz) |
Iq (Typ) (mA) |
Features |
Iout (Max) (A) |
Operating Temperature Range (C) |
Rating |
Package Group |
TPS63020-Q1 | TPS63000 | TPS63000-Q1 | TPS63010 | TPS63020 | TPS63030 | TPS63036 | TPS63070 |
Buck/Boost | Buck/Boost | Buck/Boost | Buck/Boost | Buck/Boost | Buck/Boost | Buck/Boost | Buck/Boost |
1.8 | 1.8 | 1.8 | 2 | 1.8 | 1.8 | 1.8 | 2 |
5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 16 |
1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 2.5 |
5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 9 |
4 | 1.8 | 1.8 | 2.2 | 4 | 1 | 1 | 3.6 |
100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 |
2200 | 1250 | 1250 | 2200 | 2200 | 2200 | 2200 | 2100 |
2600 | 1500 | 1500 | 2400 | 2600 | 2600 | 2600 | 2800 |
0.05 | 0.04 | 0.04 | 0.04 | 0.05 | 0.025 | 0.025 | 0.05 |
Enable Frequency Synchronization Light Load Efficiency Load Disconnect Power Good Synchronous Rectification UVLO Fixed | Enable Frequency Synchronization Light Load Efficiency Load Disconnect Synchronous Rectification UVLO Fixed | Enable Frequency Synchronization Light Load Efficiency Load Disconnect Synchronous Rectification UVLO Fixed | Dynamic Voltage Scaling Enable Frequency Synchronization Light Load Efficiency Load Disconnect Synchronous Rectification UVLO Fixed | Enable Frequency Synchronization Light Load Efficiency Load Disconnect Power Good Synchronous Rectification UVLO Fixed | Enable Frequency Synchronization Light Load Efficiency Load Disconnect Synchronous Rectification UVLO Fixed | Enable Frequency Synchronization Light Load Efficiency Load Disconnect Synchronous Rectification UVLO Fixed | Dynamic Voltage Scaling Enable Frequency Synchronization Light Load Efficiency Load Disconnect Output Discharge Power Good Synchronous Rectification UVLO Fixed Voltage Margining |
2 | 0.8 | 0.8 | 0.8 | 2 | 0.5 | 0.5 | 2 |
-40 to 125 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 125 |
Automotive | Catalog | Automotive | Catalog | Catalog | Catalog | Catalog | Catalog |
VSON | VSON | VSON | DSBGA | VSON | SON | DSBGA | VQFN-HR |
