数据: bq2409x 1A, Single-Input, Single Cell Li-Ion and Li-Pol Battery Charger 数据表
bq2409x系列器件是高度集成的锂离子和锂聚合物线性充电器器件,面向空间受限的便携式应用。这些设备可通过USB端口或AC适配器运行。具有输入过压保护的高输入电压范围支持低成本的非稳压适配器。
bq2409x具有单电源输出,可为电池充电。系统负载可以与电池并联放置,只要平均系统负载不能使电池在10小时安全定时器期间不能完全充电。
电池分三个阶段充电:调节,恒定电流和恒定电压。在所有充电阶段,内部控制环路监控IC结温,并在超出内部温度阈值时降低充电电流。
充电器功率级和充电电流检测功能完全集成。充电器功能具有高精度电流和电压调节环路,充电状态显示和充电终止。预充电电流和终止电流阈值通过外部电阻编程。快速充电电流值也可通过外部电阻编程。
所有其他商标均为其各自所有者的财产
Number of Series Cells |
Function |
Cell Chemistry |
Battery Charge Voltage (Min) (V) |
Battery Charge Voltage (Max) (V) |
Features |
Charge Current (Max) (A) |
Control Interface |
Control Topology |
Rating |
Operating Temperature Range (C) |
Pin/Package |
Operating Vin (Min) (V) |
Operating Vin (Max) (V) |
Absolute Vin (safety rating) (Max) ((V)) |
BQ24092 | BQ24090 | BQ24091 | BQ24093 | BQ24095 |
1 | 1 | 1 | 1 | 1 |
Charger | Charger | Charger | Charger | Charger |
Li-Ion/Li-Polymer | Li-Ion/Li-Polymer | Li-Ion/Li-Polymer | Li-Ion/Li-Polymer | Li-Ion/Li-Polymer |
4.2 | 4.2 | 4.2 | 4.2 | 4.35 |
JEITA BAT Temp Monitoring (Thermistor Pin) Temp Monitoring (Thermistor Pin) Thermal Regulation Vin DPM (OK for Solar Power Source) | Temp Monitoring (Thermistor Pin) Thermal Regulation Vin DPM (OK for Solar Power Source) | Temp Monitoring (Thermistor Pin) Thermal Regulation Vin DPM (OK for Solar Power Source) | JEITA BAT Temp Monitoring (Thermistor Pin) Temp Monitoring (Thermistor Pin) Thermal Regulation Vin DPM (OK for Solar Power Source) | Integrated FET Power Path Temp Monitoring (Thermistor Pin) Thermal Regulation |
1 | 1 | 1 | 1 | 1 |
Standalone (RC-Settable) | Standalone (RC-Settable) | Standalone (RC-Settable) | Standalone (RC-Settable) | Standalone (RC-Settable) |
Linear | Linear | Linear | Linear | Linear |
Catalog | Catalog | Catalog | Catalog | Catalog |
-40 to 150 | 0 to 125 | -40 to 150 | -40 to 150 | 0 to 125 |
10MSOP-PowerPAD | 10MSOP-PowerPAD | 10MSOP-PowerPAD | 10MSOP-PowerPAD | 10MSOP-PowerPAD |
4.45 | 4.45 | 4.45 | 4.45 | 4.45 |
6.45 | 6.45 | 6.45 | 6.45 | 6.45 |
12 | 12 | 12 | 12 | 12 |
