数据: bq24640 High-Efficiency Synchronous Switched-Mode Super Capacitor Charger 数据表
bq24640器件是一款高度集成的开关模式超级电容充电控制器。该器件提供恒定频率同步PWM控制器,具有高精度充电电流,电压调节和充电状态监控。
bq24640分两个阶段为超级电容充电:恒定电流和恒定电压(CC /CV) )。该器件可通过ISET引脚上的电流为0 V的超级电容充电。当超级电容器电压达到编程目标电压时,充电电流开始逐渐减小。
当输入电压低于输出电压时,bq24640进入低电流睡眠模式(<15μA)电容器电压。
bq24640有一个输入CE引脚,用于启用和禁用充电,STAT和 PG 输出引脚报告电荷和适配器状态。 bq24640上的TS引脚监控电容器的温度,并在冷热条件下暂停充电。
所有其他商标均为他们各自的所有者
Number of Series Cells |
Function |
Cell Chemistry |
Battery Charge Voltage (Min) (V) |
Battery Charge Voltage (Max) (V) |
Features |
Charge Current (Max) (A) |
Control Interface |
Control Topology |
Rating |
Operating Temperature Range (C) |
Pin/Package |
Operating Vin (Min) (V) |
Operating Vin (Max) (V) |
Absolute Vin (safety rating) (Max) ((V)) |
BQ24640 | BQ24600 | BQ24610 | BQ24616 | BQ24617 | BQ24618 | BQ24620 | BQ24630 |
1 2 3 4 5 6 7 8 | 1 2 3 4 5 6 | 1 2 3 4 5 6 | 1 2 3 4 5 6 | 1 2 3 4 5 | 1 2 3 4 5 6 | 1 2 3 4 5 6 7 | 1 2 3 4 5 6 7 |
Charger | Charger | Charger | Charger | Charger | Charger | Charger | Charger |
SuperCap | Li-Ion/Li-Polymer | Li-Ion/Li-Polymer | Li-Ion/Li-Polymer | Li-Ion/Li-Polymer | Li-Ion/Li-Polymer | Lithium phosphate | Lithium phosphate |
2.1 | 2.1 | 2.1 | 2.1 | 2.1 | 2.1 | 1.8 | 1.8 |
26 | 26 | 26 | 26 | 22 | 26 | 26 | 26 |
Temp Monitoring (Thermistor Pin) | Power Path Temp Monitoring (Thermistor Pin) | Power Path Standard BAT Temp Monitoring | JEITA BAT Temp Monitoring (Thermistor Pin) Power Path | Power Path Standard BAT Temp Monitoring | Power Path Standard BAT Temp Monitoring | Temp Monitoring (Thermistor Pin) | Temp Monitoring (Thermistor Pin) |
20 | 10 | 20 | 20 | 20 | 10 | 20 | 20 |
Standalone (RC-Settable) | Standalone (RC-Settable) | Standalone (RC-Settable) | Standalone (RC-Settable) | Standalone (RC-Settable) | Standalone (RC-Settable) | Standalone (RC-Settable) | Standalone (RC-Settable) |
Switch-Mode Buck | Switch-Mode Buck | Switch-Mode Buck | Switch-Mode Buck | Switch-Mode Buck | Switch-Mode Buck | Switch-Mode Buck | Switch-Mode Buck |
Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
-40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 |
16VQFN | 16VQFN | 24VQFN | 24VQFN | 24VQFN | 24VQFN | 16VQFN | 24VQFN |
5 | 5 | 5 | 5 | 5 | 4.7 | 5 | 5 |
28 | 28 | 28 | 28 | 24 | 28 | 28 | 28 |
33 | 33 | 33 | 33 | 33 | 33 | 33 | 33 |
