DRV11873是一款具有集成功率MOSFET的三相无传感器电机驱动器,连续驱动电流达1.5A,峰值驱动电流高达2A.DRV11873专为风扇电机驱动应用设计,噪声低且所需的外部组件数量少.DRV11873具有内置过电流保护,无需外部电流感测电阻。同步整流运行模式可提高电机驱动器应用的效率.DRV11873通过开漏输出端输出FG和RD以指示电机状态。该器件实现了适合三相电机的150°无传感器反电动势(BEMF)控制方案.DRV11873采用高效散热型16引脚TSSOP封装。额定工作温度为-40°C至125 °C。
所有商标均为其各自所有者的财产。
Vs (Min) (V) |
Vs (Max) (V) |
RMS Output Current (A) |
Peak Output Current (A) |
RDS(ON) (HS + LS) (mOhms) |
Number of Half Bridges |
Control I/F |
Features |
Rating |
Operating Temperature Range (C) |
Pin/Package |
DRV11873 | DRV10970 | DRV10975 |
5 | 5 | 6.5 |
16 | 18 | 18 |
1.5 | 1 | 1.5 |
2 | 1.5 | 2 |
450 | 400 | 250 |
3 | 3 | 3 |
PWM | PWM | PWM, Analog, or I2C |
20mA 5V LDO Rotor Lock Protection | 180 Degree Sinusoidal Commutation Adaptive Drive Angle Adjustment (ADAA) Hall Sensor Flexibility Full Protection Suite | 180 Degree Sinusoidal Commutation 100mA Step Down Buck Rotor Lock Protection |
Catalog | Catalog | Catalog |
-40 to 85 | -40 to 125 | -40 to 125 |
16HTSSOP | 24HTSSOP | 24HTSSOP 24VQFN |
