UCC2753x单通道高速栅极驱动器可有效地驱动MOSFET和IGBT电源开关.UCC2753x器件采用一种通过不对称驱动(分离输出)提供高达2.5A和5A灌电流的设计,同时结合了支持负断偏置电压,轨道轨道驱动功能,极小传播延迟(通常为17ns)的功能,是MOSFET和IGBT电源开关的理想解决方案.UCC2753x系列器件也可支持使能,双输入以及反相和同相输入功能。隔离输出与强大的不对称驱动提高了器件对寄生米勒效应的抗扰性,并有助于减少地的抖动。
输入引脚保持断开状态将使驱动器输出保持低电平。驱动器的逻辑行为显示在应用图,时序图和输入与输出逻辑真值表中。
VDD引脚上的内部电路提供一个欠压锁定功能,此功能在VDD电源电压处于工作范围内之前使用输出保持低电平。
所有商标均为其各自所有者的财产。
Number of Channels (#) |
Power Switch |
Peak Output Current (A) |
Input VCC (Min) (V) |
Input VCC (Max) (V) |
Rise Time (ns) |
Fall Time (ns) |
Prop Delay (ns) |
Input Threshold |
Channel Input Logic |
Input Negative Voltage (V) |
Features |
Rating |
Operating Temperature Range (C) |
Package Group |
UCC27536 | UCC27531 | UCC27532 | UCC27533 | UCC27537 | UCC27538 |
1 | 1 | 1 | 1 | 1 | 1 |
MOSFET IGBT SiCFET | MOSFET IGBT SiCFET | MOSFET IGBT SiCFET | MOSFET IGBT SiCFET | MOSFET IGBT SiCFET | MOSFET IGBT SiCFET |
2.5 | 5 | 5 | 5 | 5 | 5 |
10 | 10 | 10 | 10 | 10 | 10 |
32 | 32 | 32 | 32 | 32 | 32 |
15 | 15 | 15 | 15 | 15 | 15 |
7 | 7 | 7 | 7 | 7 | 7 |
17 | 17 | 17 | 17 | 17 | 17 |
CMOS TTL | CMOS TTL | CMOS | CMOS TTL | CMOS TTL | CMOS TTL |
Single Inverting | Non-Inverting Single | Single Non-Inverting | Dual Inverting Non-Inverting | Single Non-Inverting | Dual Non-Inverting |
-5 | -5 | -5 | -5 | -5 | -5 |
Enable Pin Negative Voltage Handling on Input | Split Output | Split Output | Negative Voltage Handling on Input | Enable Pin | Split Output |
Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
-40 to 140 | -40 to 125 -40 to 140 | -40 to 140 | -40 to 140 | -40 to 140 | -40 to 140 |
SOT-23 | SOIC SOT-23 | SOT-23 | SOT-23 | SOT-23 | SOT-23 |
