TUSB522P是一款支持5Gbps数据传输速率的第四代双单工通道USB 3.1 GEN 1转接驱动器和信号调节器。该器件采用<低空功耗架构能力使得该系统能够在发送和接收数据路径上保持信号的完整性。接收器均衡有三种增益设置,用以克服插入损耗和码间串扰造成的通道性能退化。这些设置由EQ引脚控制。为了补偿传输线路损耗,输出驱动器还支持使用引脚DE配置去加重功能。此外,自动LFPS去加重控制有助于实现与USB 3.1完全兼容。这些设置使得TUSB522P能够达到最佳性能,并延长信号传输距离以及实现在
USB 3.1 GEN 1路径中灵活安置。
所有商标均为其各自所有者的财产。
Device Type |
Number of Channels (#) |
Configuration |
VCC (Min) (V) |
VCC (Max) (V) |
Ron (Typ) (Ohms) |
Input/Ouput Voltage (Min) (V) |
Input/Ouput Voltage (Max) (V) |
ICC (Max) (uA) |
Bandwidth (MHz) |
ESD HBM (Typ) (kV) |
Features |
Rating |
Operating Temperature Range (C) |
Package Group |
Package Size: mm2:W x L (PKG) |
Pin/Package |
TUSB522P | TUSB1002 | TUSB1002A | TUSB501 | TUSB501-Q1 | TUSB551 |
Redriver | Redriver | Redriver | Redriver | Redriver | Redriver |
2 | 2 | 2 | 1 | 1 | 1 |
Dual-channel, Sigle-lane | Dual-channel, Dual-lane | Dual-channel, Dual-lane | Single-channel | Single-channel | Single-channel |
3 | 3 | 3 | 3 | 3 | 1.62 |
3.6 | 3.6 | 3.6 | 3.6 | 3.6 | 1.98 |
NA | NA | NA | NA | NA | |
0.1 | 0 | -0.5 | 0.1 | 0.1 | 0 |
1.2 | 1.7 | 4 | 1.2 | 1.2 | 1.2 |
98mA | 103mA | 100mA | 65mA | 65mA | 82mA |
2500 | 5000 | 5000 | 2500 | 2500 | 2500 |
6 | 5 | 5 | 5 | 4 | |
Ultra low-power architecture | Ultra-low-power architecture | Ultra-low-power architecture | Aggressive Low-Power Architecture | Aggressive Low-Power Architecture | 1.8V power Supply |
Catalog | Catalog | Catalog | Catalog | Automotive | Catalog |
-40 to 85 0 to 70 | -40 to 85 0 to 70 | -40 to 85 0 to 70 | -40 to 85 | -40 to 105 | -40 to 85 |
VQFN | VQFN | VQFN | WSON | WSON | X2QFN |
24VQFN: 16 mm2: 4 x 4(VQFN) | 24VQFN: 16 mm2: 4 x 4(VQFN) | 24VQFN: 16 mm2: 4 x 4(VQFN) | See datasheet (WSON) | See datasheet (WSON) | 12X2QFN: 3 mm2: 1.6 x 1.6(X2QFN) |
24VQFN | 24VQFN | 24VQFN | 8WSON | 8WSON | 12X2QFN |
