TSU8111是一款具有集成线性充电器的双SP2T微型USB开关。由于此器件集成有充电器,因此无需配备外部充电器IC,从而节省了成本与电路板空间。该器件可通过USB端口或专用充电器供电运行,并支持高达950mA的充电电流。连接该器件后,将通过VBAT或VBUS为其供电.TSU8111可检测与BCv1。 USB开关矩阵既可以通过自动检测来控制,也可以通过I 2 C手动进行控制。
如需了解所有可用封装,请参见数据表末尾的可订购产品附录。
所有商标均为其各自所有者的财产。
Device Type |
Number of Channels (#) |
Configuration |
VCC (Min) (V) |
VCC (Max) (V) |
Ron (Typ) (Ohms) |
Input/Ouput Voltage (Min) (V) |
Input/Ouput Voltage (Max) (V) |
ICC (Max) (uA) |
Bandwidth (MHz) |
ESD HBM (Typ) (kV) |
Features |
Rating |
Operating Temperature Range (C) |
Package Group |
Package Size: mm2:W x L (PKG) |
Pin/Package |
TSU8111 | TSU5511 | TSU5611 | TSU6111 | TSU6111A | TSU6712 | TSU6721 |
USB/MHL Switch | USB/MHL Switch | USB/MHL Switch | USB/MHL Switch | USB/MHL Switch | USB/MHL Switch | |
2 | 2 | 2 | 2 | 2 | 2 | 2 |
1:2 SPDT | 1:3 SP3T | 1:3 SP3T | 1:2 SPDT | 1:2 SPDT | 1:4 SP4T | 1:3 SP3T |
1.65 | 2.8 | 2.8 | 3 | 3 | 3 | 3 |
6.5 | 6.7 | 6.7 | 6.5 | 6.5 | 6.5 | 6.5 |
8 | 4.5 | 4.5 | 8 | 8 | 8 | 6 |
0 | -1.3 | 0 | 0 | -0.8 | -1.5 | |
3.6 | 3.6 | 3.6 | 3.6 | 3.6 | 3.6 | |
150 | 70 | See data sheet | 75 | 75 | 600 | 155 |
820 | 830 | 830 | 920 | 920 | 510 | 510 |
12 | 2 | 1.5 | 2 | 5 | 1.5 | 4 |
USB 2.0 Integrated Single-Cell Charger BCv1.1 Charger Detection Impedance Detection Thermal Regulation and Shutdown | USB 2.0 UART Audio Switch (Negative Rail Capability) Click-Pop Reduction Charging Capability I2C Interface Impedance Detection | USB 2.0 Audio Switch (Negative Rail Capability) Integrated LDO Impedance Detection | USB 2.0 UART BCv1.1 Charger Detection I2C Interface JIG and BOOT Support Attach and Detach Interrupt Surge Protection | USB 2.0 UART BCv1.1 Charger Detection I2C Interface JIG and BOOT Support Attach and Detach Interrupt Surge Protection | Audio Switch (Negative Rail Capability) Charging Capability I2C Interface JIG and BOOT Support Impedance Detection | USB 2.0 UART Audio Switch (Negative Rail Capability) ID Bypass Switch Charging Capability BCv1.2 Charger Detection I2C Interface JIG and BOOT Support Impedance Detection Attach and Detach Interrupt |
Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
-40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 |
DSBGA | DSBGA | DSBGA | UQFN | UQFN | DSBGA | DSBGA |
See datasheet (DSBGA) | See datasheet (DSBGA) | See datasheet (DSBGA) | 16UQFN: 5 mm2: 1.8 x 2.6(UQFN) | 16UQFN: 5 mm2: 1.8 x 2.6(UQFN) | See datasheet (DSBGA) | See datasheet (DSBGA) |
20DSBGA | 20DSBGA | 20DSBGA | 16UQFN | 16UQFN | 25DSBGA | 25DSBGA |
