数据: HD3SS3202 Two-Channel Differential 2:1/1:2 USB3.1 Mux/Demux 数据表
HD3SS3202是一款高速双向无源开关,采用多路复用或多路分配配置,适用于支持USB 3.1 Gen 1和Gen 2数据的USB Type-C™应用基于控制引脚SEL,器件提供端口B或端口C到端口A之间差分通道的开关。
HD3SS3202是一款通用模拟差分无源开关。它适用于需要0至2 V共模电压范围的任何高速接口应用,并且需要差分信号,差分幅度最大为1800 mVpp。该器件具有自适应跟踪功能,可确保通道在完整的共模电压范围内保持不变。
该器件允许高速开关,对信号眼图的衰减最小,几乎不增加抖动。它使用<运行时功率为1.65 mW(典型值)。它具有由OEn引脚使用的ashutdown模式,结果为< .02μW(典型值)。
所有商标均归其所有各自所有者。
Function |
Policy Manager |
Alternate Mode |
Power Role |
Data Role |
Internal Power Path |
External Power Path Control |
Realtime VBUS monitoring |
Dead Battery Support |
USB Speed (Mbps) |
Operating Temperature Range (C) |
Rating |
Configuration |
Package Group |
HD3SS3202 | HD3SS3212 | HD3SS3220 | TUSB1042I | TUSB542 |
Mux/Demux | Passive Signal Switch | CC Controller Passive Signal Switch | Active Signal Switch | Active Signal Switch |
N/A | N/A | N/A | N/A | |
No | No | No | No | No |
N/A | DRP Sink Source | N/A | N/A | |
DFP DRP UFP | DFP DRP | DFP DRD UFP | DFP DRP UFP | DFP DRD UFP |
N/A | N/A | N/A | N/A | N/A |
N/A | N/A | GPIO I2C | N/A | |
No | No | Yes | No | No |
10000 | 10000 | 10000 | 10000 | 5000 |
-40 to 85 0 to 70 | -40 to 85 0 to 70 | 0 to 70 -40 to 85 | -40 to 85 | -40 to 85 |
Catalog | Catalog | Catalog | Catalog | Catalog |
2:1/1:2 | 2:1/1:2 USB3.1 Mux/Demux No CC Control | CC Logic Port Control DRP | USB Type-C 2:1 Redriver Switch | 2:1 Mux |
UQFN | VQFN | WQFN | WQFN | X2QFN |
无样片 |
