数据: TUSB1046A-DCI USB Type-C™ DisplayPort™ 交替模式10Gbps 线性 转接驱动器交叉点开关 数据表 (Rev. A)
TUSB1046A-DCI是一种VESA USB Type-C™交替模式转接驱动开关,对于下行端口(主机),支持高达10Gbps的USB 3.1数据速率以及高达8.1Gbps的DisplayPort 1.4数据速率。这款VESA DisplayPort Alt模式器件支持基于USB Type-C标准1.1版本的配置C,D,E和F.此线性转接驱动器与协议无关,并且还支持其他USB Type-C Alt模式接口。
TUSB1046A-DCI提供多个接收线性均衡级别,用于补偿由于线缆或电路板走线损耗而产生的码间串扰(ISI)。器件由3.3V单电源供电运行,支持商业级温度范围和工业级温度范围。
所有商标均为其尊重的财产我的主人。
Function |
Policy Manager |
Alternate Mode |
Power Role |
Data Role |
Internal Power Path |
External Power Path Control |
Realtime VBUS monitoring |
Dead Battery Support |
USB Speed (Mbps) |
Operating Temperature Range (C) |
Rating |
Configuration |
Package Group |
TUSB1046A-DCI | HD3SS460 | TUSB1044 | TUSB1064 | TUSB544 | TUSB546A-DCI | TUSB564 |
Active Signal Switch | Passive Signal Switch | Active Signal Switch Bi-directional Redriver | Active Signal Switch | Bi-directional Redriver | Active Signal Switch | Active Signal Switch |
N/A | N/A | N/A | N/A | N/A | ||
Yes | Yes | Yes | Yes | Yes | Yes | Yes |
N/A | N/A | N/A | DRP | N/A | N/A | |
DFP | DFP UFP | DRP | UFP | DRP | DFP | UFP |
N/A | N/A | N/A | N/A | N/A | N/A | |
No | No | No | No | No | No | |
10000 | 5000 | 10000 | 10000 | 5000 | 5000 | 5000 |
-40 to 85 0 to 70 | -40 to 85 0 to 70 | -40 to 85 0 to 70 | -40 to 85 0 to 70 | -40 to 85 | -40 to 85 0 to 70 | -40 to 85 0 to 70 |
Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
Alternate mode / Source | Alternate mode Sink/Source | Reversible 4 Channel Linear Redriver | Alternate mode / Sink | Multi-Protocol Linear Redriver | Alternate mode / Source | Cross Point C & D |
WQFN | WQFN WQFN | WQFN | WQFN | WQFN | WQFN | WQFN |
