HD3SS460是一款高速双向无源开关,可采用复用或解复用两种配置。该器件可通过负载点(POL)控制引脚进行切换,从而适应连接器换向。该器件还可通过AMSEL控制引脚来实现双通道数据/双通道视频与所有四通道视频的复用。
该器件还针对
HD3SS460是一款通用模拟差分无源开关,适用于所有高速接口应用,前提条件是该应用在0V至2V共模电压范围内发生偏置并且具有幅值高达1800 mVpp的差分信令。该器件采用自适应跟踪,可确保信道在整个共模电压范围内保持不变。
< p>该器件具有出色的动态特性,可在信号眼图衰减最小的情况下实现高速转换,并且附加抖动极少。该器件在工作模式下的功耗&lt; 2mW,关断模式下的功耗&lt; 5μW(可通过EN引脚切换模式)。
所有商标均为其各自的商标拥有者。
Function |
Policy Manager |
Alternate Mode |
Power Role |
Data Role |
Internal Power Path |
External Power Path Control |
Realtime VBUS monitoring |
Dead Battery Support |
USB Speed (Mbps) |
Operating Temperature Range (C) |
Rating |
Configuration |
Package Group |
HD3SS460 | TUSB1044 | TUSB1046A-DCI | TUSB1064 | TUSB544 | TUSB546A-DCI | TUSB564 |
Passive Signal Switch | Active Signal Switch Bi-directional Redriver | Active Signal Switch | Active Signal Switch | Bi-directional Redriver | Active Signal Switch | Active Signal Switch |
N/A | N/A | N/A | N/A | N/A | ||
Yes | Yes | Yes | Yes | Yes | Yes | Yes |
N/A | N/A | N/A | DRP | N/A | N/A | |
DFP UFP | DRP | DFP | UFP | DRP | DFP | UFP |
N/A | N/A | N/A | N/A | N/A | N/A | |
No | No | No | No | No | No | |
5000 | 10000 | 10000 | 10000 | 5000 | 5000 | 5000 |
-40 to 85 0 to 70 | -40 to 85 0 to 70 | -40 to 85 0 to 70 | -40 to 85 0 to 70 | -40 to 85 | -40 to 85 0 to 70 | -40 to 85 0 to 70 |
Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
Alternate mode Sink/Source | Reversible 4 Channel Linear Redriver | Alternate mode / Source | Alternate mode / Sink | Multi-Protocol Linear Redriver | Alternate mode / Source | Cross Point C & D |
WQFN WQFN | WQFN | WQFN | WQFN | WQFN | WQFN | WQFN |
