数据: SN65HVD17xx Fault-Protected RS-485 Transceivers With Extended Common-Mode Range 数据表
这些设备可以承受过压故障,例如直接短路到电源,接线错误,连接器故障,电缆压坏和工具误应用。它们对ESD事件也很强大,对人体模型规格具有高度保护。
这些器件结合了差分驱动器和差分接收器,可通过单个电源供电。在?? HVD1785,?? HVD1786和?? HVD1787中,驱动器差分输出和接收器差分输入在内部连接,形成适合半双工(双线总线)通信的总线端口。在'HVD1793中,驱动器差分输出和接收器差分输入是独立的引脚,以形成适用于全双工(四线总线)通信的总线端口。这些端口具有较宽的共模电压范围,使该器件适用于长距离电缆的多点应用。这些器件的特性为?40°C至105°C。
对于具有3.3 V电源工作的类似功能,请参见SN65HVD1781(SLLS877)。
所有其他商标均为其各自所有者的财产< /small>
Supply Voltage(s) (Nom) (V) |
No. of TX |
No. of RX |
Duplex |
Signaling Rate (Max) (Mbps) |
IEC 61000-4-2 Contact (+/- kV) |
HBM ESD (kV) |
Fault Protection (V) |
Number of Nodes |
Common Mode Range |
ICC (Max) (mA) |
Isolated |
Rating |
Operating Temperature Range (C) |
Package Group |
Approx. Price (US$) |
SN65HVD1786 | SN65HVD1780 | SN65HVD1781 | SN65HVD1782 | SN65HVD1785 | SN65HVD1787 | SN65HVD1791 | SN65HVD1792 | SN65HVD1793 | SN65HVD1794 |
5 | 3.3 5 | 3.3 5 | 3.3 5 | 5 | 5 | 5 | 5 | 5 | 5 |
1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Half | Half | Half | Half | Half | Half | Full | Full | Full | Half |
1 | 0.115 | 1 | 10 | 0.115 | 10 | 0.115 | 1 | 10 | 0.115 |
N/A | N/A | N/A | N/A | N/A | N/A | N/A | N/A | N/A | N/A |
16 | 16 | 16 | 16 | 16 | 16 | 16 | 16 | 16 | 16 |
-70 to 70 | -70 to 70 | -70 to 70 | -30 to 30 | -70 to 70 | -30 to 30 | -70 to 70 | -70 to 70 | -30 to 30 | -70 to 70 |
256 | 320 | 320 | 64 | 256 | 64 | 256 | 256 | 256 | 256 |
-20 to 25 | -7 to 12 | -7 to 12 | -7 to 12 | -20 to 25 | -20 to 25 | -20 to 25 | -20 to 25 | -20 to 25 | -20 to 25 |
6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 |
No | No | No | No | No | No | No | No | No | No |
Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
-40 to 105 | -40 to 105 | -40 to 105 -40 to 125 | -40 to 105 | -40 to 105 | -40 to 105 | -40 to 105 | -40 to 105 | -40 to 105 | -40 to 105 |
PDIP SOIC | PDIP SOIC | PDIP SOIC | PDIP SOIC | PDIP SOIC | PDIP SOIC | SOIC | SOIC | SOIC | PDIP SOIC |
1.45 | 1ku | 1.85 | 1ku | 1.85 | 1ku | 1.80 | 1ku | 1.45 | 1ku | 1.80 | 1ku | 1.70 | 1ku | 1.70 | 1ku | 1.90 | 1ku | 1.95 | 1ku |
