SN65HVD5X器件是三态差分线路驱动器和差分输入线路接收器,采用5V电源供电。每个驱动器和接收器都有独立的输入和输出引脚,用于全双工总线通信设计。它们设计用于平衡传输线,并与ANSI TIA /EIA-485A,TIA /EIA-422-B,ITU-T v.11和ISO 8482:1993标准兼容设备互操作。
SN65HVD50 ,SN65HVD51和SN65HVD52完全使能,无外部使能引脚。
SN65HVD53,SN65HVD54和SN65HVD55具有高电平有效驱动器使能和低电平有效接收器使能。通过禁用驱动器和接收器,可实现低于1μA的低待机电流。
所有器件的工作温度范围均为-40°C至85°C。
SN65HVD5x的高输出功能提供比典型RS-485驱动器更高的噪声容限。额外的噪声容限使得在长电缆和恶劣噪声环境中的应用成为可能。
(1)线路的信令速率是每秒产生的电压转换次数,单位为bps(每秒位数) )。
Supply Voltage(s) (Nom) (V) |
No. of TX |
No. of RX |
Duplex |
Signaling Rate (Max) (Mbps) |
IEC 61000-4-2 Contact (+/- kV) |
HBM ESD (kV) |
Fault Protection (V) |
Number of Nodes |
Common Mode Range |
ICC (Max) (mA) |
Isolated |
Rating |
Operating Temperature Range (C) |
Package Group |
Approx. Price (US$) |
SN65HVD53 | SN65HVD30 | SN65HVD31 | SN65HVD32 | SN65HVD33 | SN65HVD34 | SN65HVD35 | SN65HVD54 | SN65HVD55 |
5 | 3.3 | 3.3 | 3.3 | 3.3 | 3.3 | 3.3 | 5 | 5 |
1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Full | Full | Full | Full | Full | Full | Full | Full | Full |
25 | 26 | 5 | 1 | 26 | 5 | 1 | 5 | 1 |
N/A | N/A | N/A | N/A | N/A | N/A | N/A | N/A | N/A |
15 | 15 | 15 | 15 | 15 | 15 | 15 | 15 | 15 |
-9 to 14 | -9 to 14 | -9 to 14 | -9 to 14 | -9 to 14 | -9 to 14 | -9 to 14 | -9 to 14 | -9 to 14 |
64 | 256 | 256 | 256 | 64 | 256 | 256 | 256 | 256 |
-7 to 12 | -7 to 12 | -7 to 12 | -7 to 12 | -7 to 12 | -7 to 12 | -7 to 12 | -7 to 12 | -7 to 12 |
2.7 | 2.1 | 6.4 | 6.4 | 2 | 6.5 | 6.5 | 8 | 8 |
No | No | No | No | No | No | No | No | No |
Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
-40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 |
SOIC | SOIC | SOIC | SOIC | SOIC VQFN | SOIC | SOIC | SOIC | SOIC |
1.45 | 1ku | 1.45 | 1ku | 1.45 | 1ku | 1.40 | 1ku | 1.40 | 1ku | 1.45 | 1ku | 1.50 | 1ku | 1.45 | 1ku | 1.45 | 1ku |
