数据: 70-V Fault-Protected RS-485 Transceivers with Cable Invert 数据表
这些设备可以承受过压故障,例如直接短路到电源,接线错误,连接器故障,电缆压坏和工具误应用。它们对ESD事件也很强大,对人体模型规格具有高度保护。
这些器件结合了差分驱动器和差分接收器,可通过单个电源供电。驱动器差分输出和接收器差分输入在内部连接,适用于适用于半双工(双线总线)通信的总线端口。电缆反相引脚(INV)允许主动校正安装期间可能发生的错误导线。在检测到通信错误时,用户可以向INV引脚施加逻辑高电平,有效地反转差分总线端口的极性,从而校正反向总线。
这些器件具有宽共模电压范围,使其适用于长电缆的多点应用。这些器件的特性为-40°C至105°C。
对于3.3 V电源工作的类似功能,请参见SN65HVD1781(SLLS877)。
Supply Voltage(s) (Nom) (V) |
No. of TX |
No. of RX |
Duplex |
Signaling Rate (Max) (Mbps) |
IEC 61000-4-2 Contact (+/- kV) |
HBM ESD (kV) |
Fault Protection (V) |
Number of Nodes |
Common Mode Range |
ICC (Max) (mA) |
Isolated |
Rating |
Operating Temperature Range (C) |
Package Group |
Approx. Price (US$) |
SN65HVD1794 | SN65HVD1780 | SN65HVD1781 | SN65HVD1782 | SN65HVD1785 | SN65HVD1786 | SN65HVD1787 | SN65HVD1791 | SN65HVD1792 | SN65HVD1793 |
5 | 3.3 5 | 3.3 5 | 3.3 5 | 5 | 5 | 5 | 5 | 5 | 5 |
1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Half | Half | Half | Half | Half | Half | Half | Full | Full | Full |
0.115 | 0.115 | 1 | 10 | 0.115 | 1 | 10 | 0.115 | 1 | 10 |
N/A | N/A | N/A | N/A | N/A | N/A | N/A | N/A | N/A | N/A |
16 | 16 | 16 | 16 | 16 | 16 | 16 | 16 | 16 | 16 |
-70 to 70 | -70 to 70 | -70 to 70 | -30 to 30 | -70 to 70 | -70 to 70 | -30 to 30 | -70 to 70 | -70 to 70 | -30 to 30 |
256 | 320 | 320 | 64 | 256 | 256 | 64 | 256 | 256 | 256 |
-20 to 25 | -7 to 12 | -7 to 12 | -7 to 12 | -20 to 25 | -20 to 25 | -20 to 25 | -20 to 25 | -20 to 25 | -20 to 25 |
6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 |
No | No | No | No | No | No | No | No | No | No |
Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
-40 to 105 | -40 to 105 | -40 to 105 -40 to 125 | -40 to 105 | -40 to 105 | -40 to 105 | -40 to 105 | -40 to 105 | -40 to 105 | -40 to 105 |
PDIP SOIC | PDIP SOIC | PDIP SOIC | PDIP SOIC | PDIP SOIC | PDIP SOIC | PDIP SOIC | SOIC | SOIC | SOIC |
1.95 | 1ku | 1.85 | 1ku | 1.85 | 1ku | 1.80 | 1ku | 1.45 | 1ku | 1.45 | 1ku | 1.80 | 1ku | 1.70 | 1ku | 1.70 | 1ku | 1.90 | 1ku |
