数据: 支持静电放电(ESD) ,用于VBUS_CON 引脚的USB 充电器过压保护(OVP)开关 数据表 (Rev. A)
TPD1S414是一款用于USB连接器的V BUS 线路保护的单芯片解决方案。此双向nFET开关在保护内部系统电路不受任何V BUS_CON 引脚上过压情况影响的同时,可确保充电和主机模式下的安全电流流量。在V BUS_CON 引脚上,这个器件能够处理高达30V超压保护。在 EN 引脚切换为低电平时,TPD1S414在接通nFET之前通过一个软启动延迟来等待20ms。 ACK 引脚表示FET完全接通。
IO Capacitance (Typ) (pF) |
Breakdown Voltage (Min) (V) |
IEC 61000-4-2 Contact (+/- kV) |
IEC 61000-4-2 Air-Gap (+/- kV) |
Interface |
Features |
Bi-/Uni-Directional |
IO Leakage Current (Max) (nA) |
Rating |
Operating Temperature Range (C) |
Package Group |
Package Size: mm2:W x L (PKG) |
Dynamic Resistance (Typ) (Ω) |
Clamping Voltage (V) |
TPD1S414 | TPD1S514 | TPD4S014 | TPD4S214 |
1.5 | 2 | ||
6 | 6 | 6 | 6 |
15 | 15 | 15 | 15 |
15 | 15 | 15 | 15 |
USB 2.0 USB 3.0 | USB 2.0 USB 3.0 | USB 2.0 | USB 2.0 |
Over Voltage Protection Surge Protection | Over Voltage Protection Surge Protection | Over Voltage Protection | Current Limit Over Voltage Protection |
Uni-Directional | Uni-Directional | Uni-Directional | Uni-Directional |
1000 | 1000 | 100 | |
Catalog | Catalog | Catalog | Catalog |
-40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 |
WSON | DSBGA | ||
See datasheet (WSON) | See datasheet (DSBGA) | ||
1 | 1 | ||
8 | 15 | 9 | |
