TMDS361B 3 选 1 HDMI 开关
数据:
The TMDS361B is a three-port digital video interface (DVI) or high-definition multimedia interface (HDMI) switch that allows up to three DVI or HDMI ports to be switched to a single display terminal. Four TMDS channels, one hot-plug detector, and a digital display control (DDC) interface are supported on each port. Each TMDS channel supports signaling rates up to 3 Gbps to allow 1080p resolution in 16-bit color depth. TMDS361B is not intended for source side applications such as external switch boxes.
The TMDS361B provides an adaptive equalizer for different ranges of cable lengths. The equalizer automatically compensates for intersymbol interference [ISI] loss of an HDMI/DVI cable for up to 20 dB at 3 Gbps.
When any of the input ports are selected, the integrated terminations (50-Ω termination resistors pulled up to VCC) are switched on for the TMDS clock channel, the TMDS clock-detection circuit is enabled, and the DDC repeater is enabled. After a valid TMDS clock is detected, the integrated termination resistors for the data lines are enabled, and the output TMDS lines are enabled. When an input port is not selected, the integrated terminations are switched off, the TMDS receivers are disabled, and the DDC repeater is disabled. Clock-detection circuitry provides an automatic power-management feature, because if no valid TMDS clock is detected, the terminations on the input TMDS data lines are disconnected and the TMDS outputs are placed in a high-impedance state.
The TMDS361B is designed to be controlled via a local I2C interface or GPIO interface based on the status of the I2C_SEL pin. The local I2C interface in TMDS361B is a slave-only I2C interface. (See the section.)
I2C Mode: When the I2C_SEL pin is set low, the device is in I2C mode. With local I2C, the interface port status can be read and the advanced configurations of the device such as TMDS output edge rate control, DDC I2C buffer output-voltage-select (OVS) settings (See the for detailed description on DDC I2C buffer description and OVS description), device power management, TMDS clock-detect feature, and TMDS input-port selection can be set. See through .
GPIO mode: When the I2C_SEL pin is set high, the device is in GPIO control mode. The port selection is controlled with source selectors, S1 and S2. The power-saving mode is controlled through the LP pin. In GPIO mode, the default TMDS output edge rate that is the fastest setting of rise and fall time is set, and the default DDC I2C buffer OVS setting (OVS3) is set. See and the for a detailed description of the DDC I2C buffer.
Following are some of the key features (advantages) that TMDS361B provides to the overall sink-side system (HDTV).
  • 3×1 switch that supports TMDS data rates up to 3 Gbps on all three input ports
  • ESD: Built-in support for high ESD protection (up to 10 kV on the HDMI source side). The HDMI source-side pins on the TMDS361B are connected via the HDMI/DVI exterior connectors and cable to the HDMI/DVI sources (e.g., DVD player). In TV applications, it can be expected that the source side may be subjected to higher ESD stresses compared to the sink side that is connected internally to the HDMI receiver.
  • Adaptive equalization: The built-in adaptive equalization support compensates for intersymbol interference [ISI] loss of up to 20 dB, which represents a typical 20-m HDMI/DVI cable at 3 Gbps. Adaptive equalization adjusts the equalization gain automatically, based on the cable length and the incoming TMDS data rate.
  • TMDS clock-detect circuitry: This feature provides an automatic power-management feature and also ensures that the TMDS output port is turned on only if there is a valid TMDS input signal. TMDS clock-detect feature can be bypassed in I2C mode; see and . It is recommended to enable the TMDS clock-detect circuitry during normal operation. However, for HDMI compliance testing (TMDS termination-voltage test), the clock-detect feature should be disabled by using the I2C mode control. If the customer requires passing the TMDS termination-voltage test in GPIO mode with the default TMDS clock-detect circuitry enabled, then a valid TMDS clock should be provided for this compliace test, so that the terminations on the TMDS data pair can be connected, and thus customer can pass the TMDS termination-voltage test.
  • DDC I2C buffer: This feature provides isolation on the source side and sink side DDC I2C capacitance, thus helping the sink system to pass system-level compliance.
  • Robust TMDS receive stage: This feature ensures that the TMDS361B can work with TMDS input signals having common-mode voltage levels that can be either compliant or non-compliant with HDMI/DVI specifications.
  • VSadj: This feature adjusts the TMDS output swing and can help the sink system to tune the output TMDS swing of the TMDS361B (if needed) based on the system requirements.
  • GPIO or local I2C interface to control the device features
  • TMDS output edge-rate control: This feature adjusts the TMDS361B TMDS output rise and fall times. There are four settings of the rise and fall times that can be chosen. The default setting is the fastest rise and fall time; the other three settings are slower. Slower edge transitions can potentially help the sink system (HDTV) in passing regulatory EMI compliance.
特性
  • 3:1水槽侧开关支持高于1920×1200的DVI和高达1080p的HDMI HDTV分辨率,具有16位色深
  • 专为高达3 Gbps的信令速率而设计
  • 支持HDMI 1.3a规范
  • 输入端的自适应均衡支持最长20米HDMI线缆
    用于1080p 12位色深的2.25 Gbps
  • TMDS输入时钟检测电路
  • DDC中继器功能
  • &lt; 2-mW低功耗模式< /li>
  • 本地I 2 C或GPIO可配置
  • 增强型ESD。 HBM:所有输入TMDS为10 kV,DDC I 2 C,HPD引脚
  • 3.3伏电源
  • 温度范围:0°C至70 °C
  • 64引脚TQFP封装:与TMDS351引脚兼容
  • 可用于非兼容输入共模HDMI信号的稳健TMDS接收级
  • 应用
    • 高清数字电视
      • LCD
      • 血浆
      • DLP
DLP是德州仪器公司的商标。
参数 与其它产品相比 重定时器、均衡器和多路复用器/开关
Device Type
Protocols
Speed (Max) (Gbps)
Number of Channels (#)
ICC (Max) (mA)
Operating Temperature Range (C)
Package Group
Package Size: mm2:W x L (PKG)
Pin/Package
TMDS361B TMDS141 TMDS171 TMDS181 TMDS261B
Switch/MUX     Redriver     Retimer     Retimer     Switch/MUX
HDMI     HDMI     HDMI     HDMI     HDMI
    3.4     6
    4     4
216     130     325     350     216
0 to 70     0 to 70     -40 to 85
0 to 70
-40 to 85
0 to 85
0 to 70
TQFP     VQFN     VQFN     VQFN     TQFP
64TQFP: 144 mm2: 12 x 12(TQFP)     40VQFN: 36 mm2: 6 x 6(VQFN)     48VQFN: 49 mm2: 7 x 7(VQFN)     48VQFN: 49 mm2: 7 x 7(VQFN)     64TQFP: 144 mm2: 12 x 12(TQFP)
64TQFP     40VQFN     48VQFN     48VQFN     64TQFP
方框图 (1)
技术文档
数据手册(1)
元器件购买 TMDS361B 相关库存
相关阅读
