ADS1278-SP 抗辐射加固 24 位 8 通道同步采样 Δ-Σ ADC
数据:
参数 与其它产品相比 精密 ADCs (<=10MSPS)
  Resolution (Bits) Sample Rate (Max) (kSPS) Number of input channels Interface Operating temperature range (C) Package Group Power consumption (Typ) (mW) Package size: mm2:W x L (PKG) Architecture Input type Multi-channel configuration Reference mode Features Input range (Max) (V) Input range (Min) (V) Analog voltage AVDD (Min) (V) Analog voltage AVDD (Max) (V) Digital supply (Min) (V) Digital supply (Max) (V) INL (Max) (+/-LSB) SINAD (dB) SNR (dB) THD (Typ) (dB) Rating   ADS1278-SP ADC128S102QML-SP ADS1282-SP 24     12     31     128     1000     4     8     8     2     SPI     Microwire (Serial I/O)
QSPI
SPI     SPI     -55 to 115
-55 to 125
25 to 25     -55 to 125
25 Only     -55 to 115
-55 to 125
25 to 25     CFP | 84     CFP | 16     CFP | 28     530     2.3     25     See datasheet (CFP)     See datasheet (CFP)     See datasheet (CFP)     Delta-Sigma     SAR     Delta-Sigma     Differential     Single-Ended     Differential     Simultaneous Sampling     Multiplexed     Multiplexed     Ext     Supply     Ext     Daisy-Chainable       PGA     5.25     5.25     1.15
3.75     0     0     -1.9
0.7     4.75     2.7     4.75     5.25     5.25     5.25     1.65     2.7     1.65     2.2     5.25     3.6     201.4     1.1     17179.9       72     122     111     72     130     -108     -87     -122     Space     Space     Space
