The ADGS1612 contains four independent single-pole/single-throw (SPST) switches. A serial peripheral interface (SPI) controls the switches. The SPI interface has robust error detection features, including cyclic redundancy check (CRC) error detection, invalid read/write address detection, and serial clock (SCLK)count error detection.
It is possible to daisy-chain multiple ADGS1612 devices together. Daisy-chaining enables the configuration of multiple devices with a minimal amount of digital lines. The ADGS1612 can also operate in burst mode to decrease the time between SPI commands.
Each switch conducts equally well in both directions when on, and each switch has an input signal range that extends to the supplies. In the off condition, signal levels up to the supplies are blocked.
The ultralow on resistance (RON) of these switches make them ideal solutions for data acquisition and gain switchingapplications where low RON and low distortion are critical. The RON profile is very flat over the full analog input range, ensuring excellent linearity and low distortion when switching audio signals. The ADGS1612 exhibits break-before-make switchingaction for use in multiplexer applications. Note that throughout this data sheet, the multifunction pin, RESET/VL, is referred to either by the entire pin name or by a single function of the pin,for example, VL, when only that function is relevant.
Product Highlight
Applications
