LTC5562 LF–7GHz Wideband Low Power Active Mixer
数据:
优势和特点
  • Wideband Frequency Range to 7GHz
  • Low Power: 2.7V to 3.6V, 40mA Supply
  • Supply Current Adjustable Down to 15mA
  • Up or Downconversion
  • OIP3: +20dBm at 3.6GHz Out
  • Conversion Gain: +1dB
  • Low LO Drive: –4dBm to +2dBm
  • LO Impedance Match Maintained During Shutdown
  • Enable Control, 10μA Shutdown Current
  • 2kV ESD (HBM and CDM)
  • –40°C to 105°C Operation
  • Small 2mm × 2mm 10-Lead QFN Package
产品详情
The LTC5562 is a versatile low power mixer optimized for applications requiring wide input bandwidth, low distortion and low LO leakage. This mixer can be used for either upconverting or downconverting applications, and provides a nominal conversion gain of 1dB. The differential input is optimized for use with a 1:1 transmission-line balun, the input is 50Ω broadband matched from 30MHz to 7GHz.
The LO can be differential or single-ended and requires only –1dBm of LO power to achieve excellent distortion and noise performance. The impedance match at the LO input is maintained during shutdown. This mixer offers low LO leakage, greatly reducing the need for output filtering to meet LO suppression requirements.
The LTC5562 uses a 3.3V supply for low power consumption and the enable control allows the part to be shut down for further power savings. The total mixer current is adjustable, by simply adding a resistor in series with the LGND pin, for applications requiring even lower power.
Applications
  • Portable Radios
  • Portable Test Instruments
  • Wireless Infrastructure
  • Fixed Wireless Access Equipment
  • VHF & UHF Mixer
  • Wireless Repeaters
方框图
技术文档
数据手册(1)
元器件购买 LTC5562 相关库存
