HMC362-DIE InGaP HBT Divide-by-4 Chip, DC - 11 GHz
数据:
优势和特点
  • Ultra Low SSB Phase Noise:
    -149 dBc/Hz
  • Wide Bandwidth
  • Output Power: -6 dBm
  • Single DC Supply: +5V
  • Small Size: 1.30x 0.69 x 0.1 mm
产品详情
The HMC362 is a low noise Divide-by-4 Static Divider with InGaP GaAs HBT technology that has a small size of 1.30 x 0.69 mm. This device operates from DC (with a square wave input) to 11 GHz input frequency with a single +5V DC supply. The low additive SSB phase noise of -149 dBc/Hz at 100 kHz offset helps the user maintain good system noise performance.
Applications
  • Satellite Communication Systems
  • Fiber Optic
  • Point-to-Point Radios
  • Point-to-Multi-Point Radios
  • VSAT
方框图
