LMZM33603 LMZM33603 4.5V 至 36V 输入、2.5V 至 13.5V 输出、3A SIMPLE SWITCHER 电源模块
数据:
产品信息
描述The LMZM33603 power module is an easy-to-use integrated power solution that combines a3-A DC-DC converter with power MOSFETs, a shielded inductor, and passives into a low-profilepackage. This power solution requires as few as four external components and eliminates the loopcompensation and magnetics part selection from the design process.The 9 mm × 7 mm × 4 mm, 18-pin, QFN package is easy to solder onto a printed circuitboard and allows a compact, low-profile point-of-load design. The full feature set including powergood, programmable UVLO, prebias start-up, as well as overcurrent and overtemperature protectionmake the LMZM33603 ideal for powering a wide range of applications.特性Complete Integrated Power SolutionAs Few as 4 External ComponentsMinimum Solution Size < 100mm29 mm × 7 mm × 4 mm QFNPackageAll Pins Accessible from Package PerimeterPin Compatiable withLMZM336024-V to 36-V Input VoltageRangeOutput Voltage Range 1 V to 13.5 V at 3 A1 V to 18 V at 2 A Efficiencies Up To 95%Adjustable Switching Frequency(200 kHz to 1.2 MHz) Allows Synchronization to an External ClockPower-GoodOutput Meets EN55011 Class A EmissionsOperating IC Junction Range:–40°C to 125°COperating Ambient Temperature: –40°C to 105°CAll trademarks are the property of their respective owners.
技术文档
数据手册(1)
元器件购买 LMZM33603 相关库存
相关阅读
