LMH6624-MIL 单/双超低噪声宽带运算放大器
数据:
产品信息
描述The LMH6624-MIL device offers wide bandwidth (1.5 GHz) with very-low-input noise (0.92nV/√Hz, 2.3 pA/√Hz) and ultra-low DC errors (100-µVVOS, ±0.1-µV/°C drift) providing very precise operational amplifiers withwide dynamic range. This enables the user to achieve closed-loop gains of greater than 10, in bothinverting and non-inverting configurations.The LMH6624-MIL traditional voltage feedback topology provides the following benefits:balanced inputs, low-offset voltage and offset current, very-low-offset drift, 81-dB open loopgain, 95-dB common-mode rejection ratio, and 88-dB power supply rejection ratio.The LMH6624-MIL device operates from 5 V to 12 V and is offered in SOT-23-5 and SOIC-8packages.特性VS = ±6 V,TA = 25°C, AV= 20 (Typical Values UnlessSpecified) Gain Bandwidth 1.5 GHz Input Voltage Noise 0.92 nV/√Hz Input Offset Voltage (Limit Over Temp) 700 µV Slew Rate 350 V/µs Slew Rate (AV = 10) 400 V/µs HD2 at f = 10 MHz, RL = 100 Ω –63 dBc HD3 at f = 10 MHz, RL = 100 Ω –80 dBc Supply Voltage Range 5 V to 12 V Improved Replacement for the CLC425 Stable for Closed Loop |AV| ≥ 10 All trademarks are the property of their respective owners.
电路图、引脚图和封装图
技术文档
数据手册(1) 相关资料(5)
元器件购买 LMH6624-MIL 相关库存
相关阅读
