LMH6639-MIL 具有禁用功能的190MHz轨到轨输出放大器
数据:
产品信息
描述 The LMH6639 is a voltage feedback operational amplifier with a rail-to-rail output drive capability of 110mA. Employing TI’s patented VIP10 process, the LMH6639 delivers a bandwidth of 190MHz at a current consumption of only 3.6mA. An input common mode voltage range extending to 0.2V below the V− and to within 1V of V+, makes the LMH6639 a true single supply op-amp. The output voltage range extends to within 30mV of either supply rail providing the user with a dynamic range that is especially desirable in low voltage applications.The LMH6639 offers a slew rate of 172V/μs resulting in a full power bandwidth of approximately 28MHz. The LMH6639 also offers protection for the input transistors by using two anti-parallel diodes and a series resistor connected across the inputs. The TON value of 83nsec combined with a settling time of 33nsec makes this device ideally suited for multiplexing applications (see application note for details). Careful attention has been paid to ensure device stability under all operating voltages and modes. The result is a very well behaved frequency response characteristic for any gain setting including +1, and excellent specifications for driving video cables including harmonic distortion of −60dBc, differential gain of 0.12% and differential phase of 0.045°特性(VS = 5V, Typical Values Unless Specified) Supply Current (No Load) 3.6mA Supply Current (Off Mode) 400μA Output Resistance (Closed Loop 1MHz) 0.186Ω −3dB BW (AV = 1) 190MHz Settling Time 33nsec Input Common Mode Voltage −0.2V to 4V Output Voltage Swing 40mV from Rails Linear Output Current 110mA Total Harmonic Distortion −60dBc Fully Characterized for 3V, 5V and ±5VNo Output Phase Reversal with CMVR ExceededExcellent Overdrive RecoveryOff Isolation 1MHz −70dB Differential Gain 0.12% Differential Phase 0.045° All trademarks are the property of their respective owners.
电路图、引脚图和封装图
技术文档
数据手册(1)
元器件购买 LMH6639-MIL 相关库存
相关阅读
