LMH2110 具有 45 dB 动态范围的 8 GHz 对数 RMS 功率检测器
数据:
产品信息
描述 The LMH2110 is a 45-dB Logarithmic RMS power detector particularly suited for accurate power measurement of modulated RF signals that exhibit large peak-to-average ratios; that is, large variations of the signal envelope. Such signals are encountered in W-CDMA and LTE cell phones. The RMS measurement topology inherently ensures a modulation insensitive measurement.The device has an RF frequency range from 50 MHz to 8 GHz. It provides an accurate, temperature and supply insensitive output voltage that relates linearly to the RF input power in dBm. The LMH2110 device has excellent conformance to a logarithmic response, enabling easy integration by using slope and intercept only, reducing calibration effort significantly. The device operates with a single supply from 2.7 V to5 V. The LMH2110 has an RF power detection range from –40 dBm to 5 dBm and is ideally suited for use in combination with a directional coupler. Alternatively, a resistive divider can be used.The device is active for EN = High; otherwise, it is in a low power-consumption shutdown mode. To save power and prevent discharge of an external filter capacitance, the output (OUT) is high-impedance during shutdown.特性 Wide Supply Range from 2.7 V to 5 V Logarithmic Root Mean Square Response 45-dB Linear-in-dB Power Detection Range Multi-Band Operation from 50 MHz to 8 GHz LOG Conformance Better than ±0.5 dB Highly Temperature Insensitive, ±0.25 dB Modulation Independent Response, 0.08 dB Minimal Slope and Intercept Variation Shutdown Functionality Tiny 6-Bump DSBGA Package
电路图、引脚图和封装图
技术文档
数据手册(1) 相关资料(2)
元器件购买 LMH2110 相关库存
相关阅读
